Once it is made you would use a circular saw to make the scarfs. Does any one have a plan like this? I found one on the internet, but I don't think there is enough information .
to make a scarf strong you need at least a 6 to 1 ratio.. a 7-1/4" blade will only cut 2-1/8" so it's useless for anything thicker than 3/8". not to mention the fact that a saw blade will not leave a very smooth surface. not a problem if you're covering it up but if it's going to show, you'll need to touch it up with a plane anyway..BillyLandry wrote:Hi afreegreek
I saw a guy demonstrate this on you tube. I think it would be easier for me to use a jig and circular saw. Thanks.
that's right.. the jig shown on the link posted is for cutting a scarf on 6 mil ply (a little less than 1/4")aggie79 wrote:Hate to let a little math get in the way, but if you try to replicate that angle of a cut in ~3/4" plywood, which you'll probably need to get the glue surface for a scarf joint, you'll need a Skil saw with about a 13" blade diameter.
no I do them with a 36 grit sanding belt and then finish it up with a block plane. but ya, if you're going to do it on thin material the jig will be fine.. and you don't need an 8 to 1 like the jig shown, 6 to one is perfectly good so you can go to 3/8" material with a 7-1/4" blade.BillyLandry wrote:afreegreek
That is good to know the circular saw way would be useless on anything more than 3/8's because the size that I would want to scarf would be 1/4 to 1/4 and 3/8 to 3/8. Were you talking about a power planer? I don't have one of those anyway.
Users browsing this forum: Jimbodub and 6 guests
