Wait, I think I found it. It's called: "Plas-T-Cote"
Check out this link:
http://www.elixirind.com/?page=products&productid=35
Copied from the page:
Roof Coatings
Elixir Industries is committed with offering the best Roof Coating in the industry. With a variety of coating products, Elixir Roof Coatings can fill a myriad of job applications.
Alkyd Fibered Roof Coating: (not suitable for rubber roofs):
Coating for metal and fiberglass roofs. Alkyd Fibered Roof Coating is a non-asphalt, high quality chemically engineered roof coating that contains long fibers, pigments and non-drying resins. It is a thick, white fibered or aluminum fibered colored coating with an amazing ability to conform to, an protect against all weather conditions. It has excellent acoustical and insulating qualities.
Fibered Asphalt Aluminum Roof Coating (not suitable for rubber roofs):
Fibered Asphalt Aluminum coating seals and protects roofs from 80% of ultra-violet sun rays. It reduces inside room temperature up to 15%. Formulated to protect metal and aluminum roofs. One gallon covers 80-100 square feet. Meets ANSI/ASTM No. D-2820 Type II.
Plas-T-Cote Elastomeric 100% Acrylic Roof Coating:
Use over asphalt roof shingles, galvanized steel, concrete, wood, polyurethane foam, and bitumas built up roofs (BUR'S). Used as a reflective and protective coating. Has outstanding exterior durability and UV resistance. Expands and contracts with the roof. Resists cracking and withstands impact. Non-polluting and non-toxic.
Plas-T-Cote Rubber roof coating:
Use over rubber roofs, at seams and tears, and to seal vents, air conditioners, etc. Has outstanding exterior durability and high adhesion to rubber. Rubber roof coating is UV resistant, and expands and contracts with roof. Resists cracking and withstands impact. Non-polluting and non-toxic.
Plas-T-Cote patching cement:
Long lasting patching cements. Stops leaks fast. Just brush it on.
Plas-T-Cote Glass Fabric: A reinforcing membrane for use on cracks 1/4" or larger. This fabric can be used with patching cement, fibered aluminum and alkyd roof coatings.
Plas-T-Cote Patching Tapes:
Pliable butyl rubber press-on tapes for roof repairs. Stops leaks fast.
Plas-T-Cote Repair kit:
A general purpose white or black plastic cement and patching compound for patching and filling cracks and holes prior to applying other coatings.
Please contact your Elixir Sales Representative for further details.
