I wrote a full write up over on offgridrving.info forums
http://offgridrving.info/forum/general-discussion/easy-axle-upgrade-for-your-trailer/
Grid Runner Adventures wrote:I wrote a full write up over on offgridrving.info forums
rainjer wrote:One thing to keep in mind is the spindles stubs are case hardened. I did the same thing and the guy that welded mine said that you had to preheat the spindles before you weld them to get a proper weld.
Jeremy
