Whew!
100+ degree temperature and 85+ percent humidity be darned.
Since it couldn't be seen, I was going to paint the lower back roll pan (below the galley lid) black instead of skinning it with aluminum, but I knew it would be one of those things that bugged me if I didn't do it. So...
It is now in place. (I think I feel better.)
Then I finished all of the trim at the bottom of the teardrop sidewalls. (The heat must have been getting to me because I didn't get any pictures.)
With the bottom trim done, I can now set the teardrop shell back on the frame. But before I did, I covered the top of the frame with window weathershield wrap. (I'll be using deck screws to attach the shell to the frame, and thought the wrap would help prevent any water intrusion.)
This stuff sticks like mad anyway, but with a black frame baking in the heat it almost welded itself to the frame. I then put the teadrop shell back on the frame. (It will be screwed down later.)
Last item for the weekend was to cut opening for the vent fan. After a little masking with tape, the el cheapo HF trim router was doing a good job on the aluminum.
And, we have a hole for the fan!
Not shown, but all my aluminum edging and trim is complete except for doors and permanently attaching the hatch edging.
That summed up my weekend. Time for some cold adult beverages.
Gig'em, Tom
