Well it's official. ZooZooBee build. 4/27/11: Done !
Postby tcolar » Thu Aug 19, 2010 2:13 pm
8/18/2010
Received the window of ebay (42*26)
Closed a wall using laminating epoxy and PL foam glue and applied weight with whatever heavy stuff on hand:
Then cut out openings and applied CPES (stinky !):
Finished wall:
Messy garage .. gotta clean it up before the wife comes back !
tcolar
Images: 15
Postby tcolar » Thu Aug 26, 2010 11:15 am
@Cliffmeister2000 : When I posted the pic I had the same thought ... had to go double check ... the pic angle make it look that way, but no, it's not shorter (overhangs the same length at the other end), the radius and pic angle are deceiving.
tcolar
Images: 15
Postby tcolar » Thu Aug 26, 2010 11:17 am
Not a ton of progress as I was gone all weekend and now The wife and kids are back and demanding attention.
Anyhow, working on the other wall:
tcolar
Images: 15
Postby aggie79 » Thu Aug 26, 2010 2:08 pm
TC (is that what everyone calls you?)
Your build progress is really moving along! Thanks for the pics and updates. At this pace, you'll be camping in about 1/3 of the time that I will be.
That's a big 10-4 on the smell from the CPES. My goof-up was that I applied it in the afternoon and then had to move everything back inside the garage because of impending rain. The smell permeated throughout our small home.
On a side note, when you post an update, you can go back to your first post and edit it to change the title of your build thread - something like "ZooZooBee - August 25 update - p. 3"
Postby tcolar » Wed Sep 01, 2010 12:20 pm
August 24-31st.
Continued working on wall #2
Cut openings and insulated:
Can you find my 3 years old in the picture ? (Hint: "caged") :)
Then closed the wall (epoxy/foam glue) and applied weight:
And applied stinky CPES to outer skin:
Painted the inside of the walls too, and added a last coat of epoxy paint on the floor.
Next steps are sanding the wall bottom, and dry fitting them to the floor.
Then I'll apply a bunch more CPES to trailer floor edge and walls bottom.
Then it will be time to raise the walls, hopefully by this weekend - Excited about this step, it will start looking like a trailer :)
tcolar
Images: 15
Postby tcolar » Sat Sep 04, 2010 5:11 pm
9/3/2010: Walls up !
I spent quite lot of time finishing prepartion on the walls on floor so they could be mounted, lots of sanding / CPES etc...
Yesterday I prepared the end walls framing (so I could use them to support the side walls), I set/glued them on the hardwood floor to ensure it was straight and square.
Ended up having to start this over as I had measured wrong (cm / inches screwup)
I lined up the PVC electrical wiring from the walls with the floor and drilled the holes lining up and put some cpes on the hole walls, jst in case water get there at some point.
I set the endwalls up (epoxied) and reneforced them, especially the front (wind pressure)
Then set one wall up - lots of epoxy and some deck screws from nder the floor and where it meets the wall ends.
Then the other wall up:
It looks like a trailer now !! n :thumbsup:
tcolar
Images: 15
In a pinch...
Postby myoung » Sat Sep 04, 2010 6:43 pm
I enjoy following your build and the creative use of weights!!
Seeing what you have done, I've reconsidered outside wall sheathing. I had planned to save the task until last, but now think that all my wiring will go in either the roof or inside cabinets structures on the interior, so I'll sheath before assembly.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sat Sep 04, 2010 8:01 pm
looking good!
Just a note from my experience and many others on the forum...
If you can sheath the inside walls now, before you put a lid on it, it will be much easier!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby azmotoman » Tue Sep 07, 2010 12:22 pm
LOTS of patience in this one. Go for it! Any help from the wife and kids? Do they share in your enthusiasm/obsession?
Mine is patiently waiting her turn. She will do the final sanding and finish. I HATE that stuff, but she loves it (and she is good at it). I just finished sealing the galley area with RTV and am waiting for a couple of hours to cure before installing the weather stripping. :twisted:
Money isn't everything, but it keeps the kids in touch!
Dinero isn' ¡t todo, pero él mantiene el interés de los niños!
azmotoman
Images: 10
Postby absolutsnwbrdr » Tue Sep 07, 2010 2:16 pm
Don't know how, but looks like I'm showing up a little bit late to this party.... it looks good! Nice compass that you used... appears to be the same brand as mine!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby tcolar » Mon Sep 13, 2010 11:37 am
9/4/2010: Trailer electrical
I was a bit under the weather, so instead of doing heavy lifting, I worked on the trailer electrical (street lights):
No lifiting but lots of crawling :) under the trailer.
tcolar
Images: 15
Postby tcolar » Mon Sep 13, 2010 11:39 am
9/5/2010:
I worked on the wheel wells, using the split ion half cement mixing bucket - worked great !
tcolar
Images: 15
Postby tcolar » Mon Sep 13, 2010 11:44 am
9/6/2010:
I started some work on the electrical (inside trailer), spent a lot of time gathering the supplies.
Mounted / wired the breaker box and Inverter(they will be inside a vented cabinet later).
I'm actually doing a fully 110V system because I would mostly be using shore power and I find 12V parts to be overpriced for the most part, and 110v stuff is more readily available.
More electrical work will be done while the roof spars are up.
I keep banging my head in the doorway (hard) .... so this helps :) :
tcolar
Images: 15
Postby tcolar » Mon Sep 13, 2010 11:49 am
9/8/2010 - 9/12/2010
I welded a jack (which can be swung horizontal):
I've decided to do most of the large inside features(seating/beds/cabinets) before putting the roof, much easier to work while I can stand.
Here is my son trying is bed, that doubles as large storage compartment(hinged) - want weight in the back to keep tongue weight in check.
tcolar
Images: 15
Postby Cliffmeister2000 » Mon Sep 13, 2010 1:56 pm
Good looking crew you've got there! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
