The Fantastic Fan Order..
Postby Classic Finn » Fri Jan 06, 2006 9:49 am
Ira wrote:Finn, even though you frame the opening 14.25 by 14.25 (I knew Madjack would know that), depending on the dimensions of your spar lumber, you may have to add extra sticks of lumber around that framing.
In other words, when you go to screw the fan in, the screws may just go into air. Know what I mean? Like for mine, the 1 by 2s I used weren't wide enough, so I had to add extra 1 by 2s around it.
Thank God someone told me this before I framed mine, and before I skinned. If you have your fan before you skin, you're cool, because you can test the fit.
Ira or Madjack - I,ll remember what you said about the framing part of it as well.
Thanks
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Postby mikeschn » Fri Jan 06, 2006 10:35 am
Hey Finn,
All you have to do is frame in your vent with 2x2 studs (measured 1 1/2" x 1 1/2" on that fancy American tape measure you have!)
Make it look like this...
Thanks
Classic Finn
Images: 479
Postby Ira » Fri Jan 06, 2006 10:48 am
Mike's right, but since you'll probably be using 1 by 2s for your spars anyway, whether you double them up or not, you can just use that same lumber by adding an extra piece.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Classic Finn » Fri Jan 06, 2006 11:12 am
I have bought equivalent to 1 x 2 spar material but I also have the 2 x 2,s
as well.....so were set ...
All right!!! ;) Nice Drawing Mike
Classic Finn
PS: Is 12" apart enough for the spars from front to back or can I go farther apart?
Classic Finn
Images: 146
Postby Nitetimes » Fri Jan 06, 2006 11:32 am
Classic Finn wrote:I have bought equivalent to 1 x 2 spar material but I also have the 2 x 2,s
Classic Finn
You can adjust them to whatever you need, mine are closer on the radiused areas than on the flats, about 9-10" compared to about 11-13" on the flatter areas. I pretty much went by how much distance I had in a particular area and spaced them as equally as possible. I also adjusted them for the ceiling seems and cabinets, so come to think of it I don't think I have 2 the same!
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Ira » Fri Jan 06, 2006 11:40 am
It's funny how you forget these things, but I don't think I went anywhere near as close as 12". More like 18", maybe even a little further apart. I DO know that I made them closer than the Cubby plans called for, therefore using more in the plan as well.
But I doubled up my 1 by 2s, so the spars measured 1 1/2 by 1 1/2 after laminating.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Classic Finn » Fri Jan 06, 2006 12:26 pm
Thats good to know.. I just thought there had to be 12 " for some reason.
dont know why.... :lol:
Classic Finn
Classic Finn
Images: 146
Postby Mike Spicer » Fri Jan 06, 2006 10:03 pm
You may want to check this Maxxfan out, same as a fantastic fan but has a Rain cover built into it. I took my fantastic fan out before I went to Alaska last summer and installed one of them. Cost is about $250 but it was worth it. I also have awning windows, Great ventalation while raining. It also fits in the standard 14"x14" or 14 1/4" x 14 1/4" opening. I made my opening 14x14
Max Fan p/n 00-051000 white cover
Max Fan p/n 00-052000 smoke cover
http://www.rvupgradestore.com/index.asp ... &ProdID=80
http://www.campingworld.com/browse/prod ... rodID=4568
Mike Spicer
[/img][/url]
Home Built 4x10
Mike Spicer
Images: 14
Postby Classic Finn » Sat Jan 28, 2006 10:50 am
Hey Guys
Thought Id let you know that Scott from the" FINNTASTIC FAN" Company
http://members.aol.com/fantasticvent/index.htm
has been in touch with me and I must say that even being so far away
from all of you - Scott,s Customer Service is Incredible....and detailed as to what we need, color, size, model, dimensions and all..
I,ll recommend these folks anytime...
Had to let you know... :thumbsup: :thumbsup:
Im ordering Model 5000rtb - The Price is good as well...
Thanks Scott....
Classic Finn and Family
Classic Finn
Images: 146
Postby asianflava » Sat Jan 28, 2006 3:35 pm
The Finntastic Fan for the Fantastic Finn?
asianflava
Postby Classic Finn » Sat Feb 04, 2006 6:29 pm
madjack wrote:
Ken A Hood wrote:http://members.aol.com/fantasticvent/index.htm
If you email them with your roof thickness they will give you the correct garnish. And they have several different styles/modeels low profile, and colored dome options
Heikki, this is the guy I got my fan from, 3sp reversible. low profile with smoked/flat dome...the were really great to work with and they made damn sure I got what I wanted before they shipped...I highly recommend them
madjack 8)
Madjack
PS - Now its just PATIENCE to get all the parts here....Patience? okay I have Patience.... :cry: :cry: I want the parts here NOW.... :cry:
Its now Official - Im the happy owner of a Brand New 5000RTB Finntastic Fan... :lol:
WOW What a Guy - Scott sure is a pleasure to work with.... He knows his
Fan Business... Your so right Madjack...
He sure can help a Greenhorn ....
We had trouble communicating with the email I was sending him email to
aol.com - some would go thru and some would bounce back... :thinking:
He sent me email 1st and I answered and it went thru swell.. then the next day nothing...But we finally worked it all out via Hotmail... no problem then we spoke over the phone...
So this is what I got::: for the professionals that have already the fans installed and teardrops built....
This is what I will be sending: 1-5000rbt, low profile base, white interior, smoked standard
dome, and a short shafted lift knob. (Aliner) To fit 1 7/8"
thickness. (Garnish will be trimmed to 1 3/8")
So How did we do choice wise? Comments? :lol: :lol:
My comment is - Great Customer Service to the Detail...Nice Man also...
I,ll recommend to anyone near and far..
Thank You Scott
Classic Finn :thumbsup:
Classic Finn
Images: 146
Postby madjack » Sat Feb 04, 2006 6:32 pm
Heikki...good to hear you got it done...I have found Scott a real pleasure to work with, he will bend over backwards to see that you get exactly what you need/want :thumbsup: :thumbsup: he is exactly as a vendor should be
madjack 8)
Postby Classic Finn » Sat Feb 04, 2006 6:36 pm
Madjack - Also - He stated to check the Fan for Shipping Damage... to let him know asap either way...Double checked adress - the works ....
Talk about the Service - WOW...
Almost like a Jet Airliner Take Off check List - Check and double Check
:thumbsup: :thumbsup: :applause: :applause:
Classic Finn
Classic Finn
Images: 146
Postby cracker39 » Sat Feb 04, 2006 6:37 pm
I'll soon order the 4000, but that description fits what I want....eggsactly.
Dale
cracker39
Images: 233
Postby Classic Finn » Sat Feb 04, 2006 6:41 pm
cracker39 wrote:I'll soon order the 4000, but that description fits what I want....eggsactly.
Cracker 39
I know Scott will provide you with the same service.....Excellent...
I ordered the 5000 since its not the most expensive nor the least expensive but since the distance is so long I thought I would go with this....
There in The Good Ol USA you have shipping included in the price as well..
Classic Finn :thumbsup: ;)
Classic Finn
Images: 146
