kirkman wrote:Thanks guys! I am going with Marti because Kristi said she cant make one as big as I need it.
Look forward to seeing Marti's work. Needless to say, drop some
Scott
nevadatear wrote:
Oasis Maker wrote:The smart thing about these on a vintage awning application is that fiberglass shock corded tent poles didn't exist back then. (Or at least it obviously wasn't a part of the standard designs.)
Scott
Gage wrote:Oasis Maker wrote:The smart thing about these on a vintage awning application is that fiberglass shock corded tent poles didn't exist back then. (Or at least it obviously wasn't a part of the standard designs.)
Scott
Nothing wrong with upgrades. And it still keeps it vintage.
Oasis Maker wrote:Owners will chime in for sure, but I believe this is just fiberglass shock corded tent poles. I have this same tent pole setup on a modern screen room. The smart thing about these on a vintage awning application is that fiberglass shock corded tent poles didn't exist back then. (Or at least it obviously wasn't a part of the standard designs.)
Scott
Hikerjohnd wrote:Oasis Maker wrote:Owners will chime in for sure, but I believe this is just fiberglass shock corded tent poles. I have this same tent pole setup on a modern screen room. The smart thing about these on a vintage awning application is that fiberglass shock corded tent poles didn't exist back then. (Or at least it obviously wasn't a part of the standard designs.)
Scott
Ah- I saw the fiberglass poles but thought there was some kind of hub in the center. Maybe that's just tape or Velcro to keep the center together.
I am making my own awning out of silnylon. Nothing fancy, mostly just for shade!
Classic Finn wrote:Do any of you have an idea as to how an awning can be installed to the Kit tear without the old style frame?
doug hodder wrote:When you order your awning, you have to tell them that you want a heavy pocket in the corners as well as the grommets to receive a shock corded pole and a velcro tab or ties in the center. Once you get the awning, it takes a while to figure out just how long the poles need to be. Either buy the poles new, or get a garage sale/ thrift store tent and rob the poles from it. If they are too short, the awning can invert, and turn into a bath tub. Each awning will have it's own "sweet spot" for the correct length. Marti has done it on both of mine and she's familiar with what needs to be done to make it all work out.
Once set up, if it is a wind free area, guy ropes aren't required, it's free standing at least up to the sizes I've done, and if you do have to put them up, you can keep them close to the support poles since all you are doing is holding it down. The glass ribs create the tension on the canvas, not the ropes. It's the easiest way to create headroom on an awning on a low trailer like a tear in my opinion. Cabelas, has adjustable aluminum poles that are really nice with a cam lock on them.
It's worked slick for me, been through 6" of rain at the Dam(p) gathering 2 years ago....once in a while I get lucky with a good idea. Doug
starleen2 wrote:doug hodder wrote:When you order your awning, you have to tell them that you want a heavy pocket in the corners as well as the grommets to receive a shock corded pole and a velcro tab or ties in the center. Once you get the awning, it takes a while to figure out just how long the poles need to be. Either buy the poles new, or get a garage sale/ thrift store tent and rob the poles from it. If they are too short, the awning can invert, and turn into a bath tub. Each awning will have it's own "sweet spot" for the correct length. Marti has done it on both of mine and she's familiar with what needs to be done to make it all work out.
Thanks to Doug H. who’s inspiration helped me to solve a droopy center with the fiberglass rods. – It measures 6ft X 6ft – Plenty of room for relaxing in chairs and providing shade for the table. It’s made of sunbrella outdoor red and white stripe. The rods are actually fiberglass reflecting rods ( the kind used for marking diveways) and some plumbing pipe that I used to get the same effect. The support poles are ½ electrical conduit. The whole unit slides in a an awing channel and pretty much supports itself. I wanted the cabana look with the horizontal and vertical stripes.
starleen2 wrote:
Thanks to Doug H. who’s inspiration helped me to solve a droopy center . . .
