by eamarquardt » Wed Mar 23, 2011 1:10 pm
You'll have to modify a recycled axle to mount it to your frame. That will be a bit of work and will require additional materials/parts to be custom fabricated. The axle may or may not be the exact width you want for your trailer and if you want it narrower/wider additional time, effort, and materials will be required.
If one of these "custom" mounting parts fails while you're on the road, you may or may not be able to get it fixed at a reasonable price depending on the "mercy" of who you meet with the materials and skills to put you back on the road. I don't see any advantage to having a recycled axle versus a standard trailer axle/springs as far as parts availability while on the road.
The brakes on a recycled axle will be hydraulic and will require a hydraulic actuator be installed to couple the trailer to the tow vehicle. These couplers cost a minimum of $120 and go up from there. Are you sure you want hydraulic brakes? Most folks seem to go with electric brakes on their trailers. Retrofitting to electric brakes would take considerable effort and IMHO wouldn't be cost effective.
If you scrounge around you can find used tires and rims for very little. A new axle with brakes, mounting hardware, and springs will set you back about $350. The cost of an electric brake controller is about or perhaps a bit less than the hydraulic coupler so that part of the "equation" is a wash.
So, depending on what value you put on your time, what you will have to realistically spend for a used axle, and the service issues, you may or may not come out ahead. You might be able to save a couple hundred bucks but there will be "compromises" and it will take a fair amount of effort.
However, it's your project, your budget, so you get to decide.
Hope this helps.
Cheers,
Gus
