Figured out my hub problem. Someone used the wrong seals. The one in there was 1.978" o.d., the correct one is 1.987". Also, the one in there was only 0.185" wide, the right one should be 0.4". As a result of the wrong seal being in there, the seals were spinning in the hub, and the inner bearings were spinning when they were NOT supposed to be! Simple fix, NAPA part # 28 is the correct seal and bearing kit. Outer bearings were fine, but both inners were not.
Also got the rear hatch open and can see I have a bit of wiring to do. No biggie, but I do want to figure out how to power a few lights with 12V. I have been putting all my exploration pics in my album, feel free to check it out.
Frank
