I haven't seen this mentioned so thought I'd throw it out there. I used to mess with foam a bit making theatrical scenery many years ago. Some of the techniques were very similar to the way you folks here are doing your Foamies. It's only a matter of time before folks start getting artsy on the shape of these Foamies as the basics get sorted out.
Anyway my favorite tool for working styrofoam is a Surform plane. AKA a cheese grater. The come in big, small, flat, round, and 1/2 round styles. They chew through foam like hot butter and are easy to control once you get the hang of it. Great for precise shaping and joinery. Just like wood cut your joints tight and hand shape them with the file.
Some pics.
http://www.google.com/products/catalog? ... CFgQ8wIwAw
http://www.google.com/products/catalog? ... CFwQ8wIwBA
http://shop.pitsco.com/store/detail.aspx?ID=2712&bhcp=1
No affiliation with the above just web pics to show the tools.
Here is another great shaping tool. a 4 way rasp. It has a flat and round side in both coarse and fine.
http://www.google.com/products/catalog? ... CFcQ8wIwAg
I saw a pic of someone making both side match on their Foamie. These tools could be a big help in that kind of work.
All these are also great on wood. But the above are all RASPS and should be considered rough shaping tools. Especially on wood. A little sanding after these do their job is often needed for finish work.
Like anything else test on a scrap piece till you get the hang of it.
Also a word on saws and foam. Any dull blade will cut foam. Use an old one. Both for power and hand saws. Styrofoam is tough stuff with a zillion tough little cells of plastic. These will dull in new high quality blade in moments. So don't waste a good one use your old stuff. The exception might be sabre saw blades. Those are pretty much disposable anyway.
I having thoughts on making a simple doweling jig out of wood. Like you would use for putting pieces of a wooden tabletop together. That way for making sides that are larger than 4x8 you could end dowel these pieces together. It would help alignment and shear strength. Maybe use a 1/2" x 12 drill bit. Just something for straight edge drilling of foam panels say maybe 4" - 6" deep. Same for doweling window and door frames in place.
Something like this made out of 1x plank.
http://www.google.com/products/catalog? ... CFoQ8wIwAQ
I hope this info can be of use to someone. Feel free to add your tool tips to this thread.
