What type of sealant to use for aluminum roof edging?
Postby aggie79 » Mon Jul 25, 2011 8:09 am
Terry,
I ran a few strips of blue painter tape underneath the trim extending beyond where the trim would go. I pre-fit all the trim, including drilling holes for the screws and fastening the screws. Then I took a utility knife and scored along the edge of the trim. I removed the screws and trim, and peeled up the portion of the blue tape that was under the trim. I injected sealant into the holes (had to cut part of the tip off the syringe to get it to flow) and applied sealant to the trim, and fastened the trim in place.
Once the sealant cured, I ran the utility knife back along the edge of the trim. I then pulled up the blue tape and this removed the bead of sealant squeeze out. A little of the sealant adhered to the trim. I cleaned up the leftover sealant with a scotchbright pad - the type that doesn't scratch - and a little denatured alcohol. I left the squeeze out around the screw heads because they will be covered with vinyl trim.
Take care,
Postby LDK » Mon Jul 25, 2011 8:52 am
I wonder what would be a good brand of polyurathane caulk to use that you can get at lowes or home depot.
LDK
Postby terryjones1 » Mon Jul 25, 2011 8:57 am
aggie79 wrote:Terry,
Once the sealant cured, I ran the utility knife back along the edge of the trim. I then pulled up the blue tape and this removed the bead of sealant squeeze out. A little of the sealant adhered to the trim. I cleaned up with the scotchbright pad - the type that doesn't scratch and a little denatured alcohol. I left the squeeze out around the screw heads because they will be covered with vinyl trim.
Take care,
Thanks!
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby Cary Winch » Wed Jul 27, 2011 9:42 am
Larry,
The Sikaflex 221 mentioned earlier is a Polyurethane sealant like you are looking for. This is what I would recommend using. Clean up is soooo much easier as earlier stated than silicones. Let it squirt out and set up. Then the next day trim with a utility knife and peel off the bead. Don't try to wipe it off wet, it will make a grand mess. Clean up any excess with a paper towel and some lacquer thinner and you are good to go.
Cary
Cary Winch
Teardrop Manufacturer
Postby J.Heyboer » Wed Jul 27, 2011 11:47 am
Any idea how much sealant it takes to trim a standard teardrop? (# of tubes or oz)
Thanks,
John
J.Heyboer
Images: 84
Postby David S » Fri Jul 29, 2011 10:39 am
John,
That would depend on length of molding
I have a little over 30 ft to do and figure 2 of the 10 oz caulking sized tubes will do it.
David.
David S
Images: 53
