Recently, hybrid FRS/GMRS consumer radios have been introduced with 22 channels, instead of the 14 channels associated with FRS. On this type of radio, channels 8-14 are strictly license-free FRS channels.
The FCC rules for use of hybrid radios on channels 1-7 require licensing only when operating under the rules that apply to the GMRS.[8] Many hybrid radios have an ERP that is lower than one half watt on channels 1-7, or can be set by the user to operate at low power on these channels. This allows hybrid radios to be used under the license free FRS rules if the ERP is less than one half watt and the unit is certified for FRS operation. Only two makers of hybrid FRS/GMRS radios (Garmin and Motorola) presently sell radios that will operate on the GMRS repeater channels; the common "22 channel" radios cannot be used with GMRS repeaters. The Icom IC-F21GM is a solely-GMRS radio which will also work repeaters.
Hybrid packaging still contains the notice of the FCC licensing requirement. Estimates of the number of hybrid FRS/GMRS radios sold to date range from 20 to 50 million units or more. This is compared with approximately 80,000 active GMRS licensees (per the FCC database). Enforcement against individuals is rarely, if ever, attempted.
Mukilteo wrote:Slowcowboy, I know a gal I could send your way.
After which, you would find that being alone ain't all that bad after all.
