Larry C wrote: In 1985 I bought a Toyota Tercel with a 1.5L engine. I would frequently take backpacking trips where I would drive 1000 miles or more with 4 people and 4 full packs, get 42MPG, and pull all hills the mountains could throw at us.
Today's cars, with engines almost twice the size would be hard pressed to carry the same load without struggling. I kept the Tercel for 19.5 years.
Larry
Pete S wrote:I haven't looked at the VW or Suburu lines because the MPGs are comparatively low. If I remember right some are in line with small pickups. Defeats the purpose of getting a small car....
Mojave Bob wrote:There is power and there is power. Back in the 70s and 80s, it was almost impossible to purchase a modest car with significantly over 100 HP, and small cars had 60-85 HP. It was adequate, but certainly not surplus power. Top speeds typically fell short of 100 mph, but that was ok, since the speed limit was 55mph. Even the Corvette in 1975 had only 165 HP.
Fast forward to today, and most small cars have 130-200 hp, with only the smallest cars having under 120. The Chevy Cruze has 138 HP. The Mazda 3 has 167 (more than a '75 'Vette). My experience is that virtually anything built today will outrun virtually anything from 35 years ago. Today's cars will cruise the interstate effortlessly at 75-85 mph, while 35 years ago, most cars were pretty close to topped out at that speed.
I drive "older" cars (a '95 and an '01). The '01 will run circles around the '95, up to about 70mph, when the roles reverse. When I have a chance to drive newer cars, I am always struck by how much more acceleration they have than my cars do.
I suspect that that may not be linear when towing, particularly with an automatic transmission, however. New cars are geared for optimum cruising efficiency, while my '01 takes more of a "shoot up the middle" approach, keeping the engine revs higher, which keeps me more in my peak power curve. If you work the gears on your new car manually, and run the revs up into the power curve, a new car would have more power, at the expense of the gas mileage.
whitefishpoint wrote: Huh? TDI diesels get 40 mpg and have 230 ft-lbs of torque. I have a subaru outback and it gets 34 mpg highway and 21 mpg when I'm towing my 6x10 trailer full of gear.
mikeschn wrote:You had a 78 Plymouth Arrow. That reminds me of my 78 Dodge Colt Challenger. 1.6L, with a top speed of 78mph!![]()
Pete S wrote:whitefishpoint wrote:
The Outback doesn't break 30 mpg at fueleconomy.gov even in 4 cylinder trim and without a trailer. As best I can tell the newer Outbacks now compare in size to the bigger CUVs, not exactly just a car anymore.
We are getting 30mpg exactly in combined driving with our Forester. We didn't get that when it was new, but we are near 90k miles now, and the fuel economy just keeps getting better. Or maybe it's my driving.![]()
What year?
slowcowboy wrote:I tell you guys what. my old 78 toyota with a 20R engine and a cabrator had way more power than any ford I have owned since.
my toyota had dirct 5 gear not over drive.
this tranny problem is a lot of the problems in the new cars.
they put a guttless overdrive into the tranny for high gear instead of a dirct power 5 gear.
SLow.
What year?
