Heated Mattress Pads
Postby 86bigred » Wed Aug 03, 2011 11:16 pm
i had a 12 volt one when i did long haul trucking,just pined it to the mattress, and sheets on top.it saved my bacon one night at -30 deg and my freightliner blew a rad hose in the middle of nowhere.kept me pretty warm for the night,plus it was nice to get into a warm bed every night.
86bigred
Postby droid_ca » Wed Aug 03, 2011 11:43 pm
I live on the colder side of the globe and was wondering would it be advisable to add an extra battery for when using electric pads, blankets, heaters, and what not?
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby halfdome, Danny » Thu Aug 04, 2011 7:19 am
Wild Bill, Sorry to hear about your mattress fire.
I've been using heated mattress pads for 40 years now with no fires or other mishaps. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby b.bodemer » Thu Aug 04, 2011 9:29 am
I bought the same for my teardrop. I took it in the house and gave it a test. Worked so well over the winter months it never left my bedroom! :lol: :lol:
Barb
b.bodemer
Images: 328
Postby stumphugger » Sat Oct 08, 2011 10:09 pm
I'm bumping this up. I'm starting to shop for one. The Used Dog cannot go on every trip with me, although he'd like to, so I need some heat. My trailer is only plumbed for 12 volt power.
Now, mattress pad or electric blanket? I have warm sleeping bags so would only turn it on to heat the bed up before bedtime. It seems like it took a while to heat up the foam mattress when it was just me and The Used Dog on a December night.
stumphugger
Images: 76
Postby halfdome, Danny » Sat Oct 08, 2011 10:26 pm
stumphugger wrote:I'm bumping this up. I'm starting to shop for one. The Used Dog cannot go on every trip with me, although he'd like to, so I need some heat. My trailer is only plumbed for 12 volt power.
A mattress pad will retain the heat under covers and warms whatever part of your body it contacts. An electric blanket is a lot cheaper and heats above you casting the heat into the surrounding area and partially warming your body, not very efficient. Your suppose to not put covers over an electric blanket for safety reasons. The choice is yours. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby stumphugger » Sat Oct 08, 2011 11:17 pm
OK, I bit the bullet and ordered a small warmer. I'm doing a couple days of volunteer trail work later on. I want to be warm at night. Warm can be a good thing. :)
Also had to get a new battery for the trailer last month. :(
stumphugger
Images: 76
Postby Pottercounty » Sun Oct 09, 2011 4:55 am
We use a twin size electric blanket underneath a 3 inch down filled Duvae and even at below freezing, we stay very cozy with the dial set on the 4th number. We looked at heated mattress pads but they were 20-30% more costly. I would probably use your heated mattress pad on top of the memory foam as the density will prevent heating up quickly however, try it both ways and see what works for you..
best, Tim
Those are my principles. If you don't like them I have others.
Groucho Marx (1890-1977)
Pottercounty
Images: 20
Postby bdosborn » Sun Oct 09, 2011 11:05 am
The cheapest place I could find the electrowarmth mattress heater is here:
Backwoods Solar
I was going to run the single size across the middle of the Boxcar's queen size bed but I put in a diesel heater instead.
Images: 806
Postby halfdome, Danny » Sun Oct 09, 2011 11:09 am
Pottercounty wrote: I would probably use your heated mattress pad on top of the memory foam as the density will prevent heating up quickly however, try it both ways and see what works for you..
http://www.Electrowarmth.com mattress pads recommend not covering it with heavy items.
A foam topper over the mattress warming pad will make it over heat and could possibility cause a fire. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby wired » Sun Oct 09, 2011 11:36 am
A number of years ago my parents woke up to their bed on fire from an electric blanket. My dad got 2nd & 3rd degree burns on his hands trying to put it out. They were both lucky. Personally, I would never use an electric blanket nor an electric heated mattress pad.
wired
Postby stumphugger » Sun Oct 09, 2011 7:45 pm
I'm thinking it will be quite safe. I plan to plug it in to warm things up, then unplug it for the rest of the night. The way I am, it would be too warm for all night.
stumphugger
Images: 76
Postby tearhead » Mon Oct 10, 2011 6:58 pm
Kohls has electric m$60. I love ours (which I paid 90 something for).
Pat from Wisconsin
tearhead
Images: 15
Postby Juneaudave » Mon Oct 10, 2011 8:29 pm
I really like our electrowarmth pad. It goes two nights before the battery is drained. Usually I set it on medium to warm the bed and low for sleeping or else it will roast you out. It is surprising how comfortable the trailer is, and how little it takes to warm it up.
Juneaudave
Images: 380
Postby stumphugger » Tue Oct 11, 2011 9:11 am
Juneaudave wrote:I really like our electrowarmth pad. It goes two nights before the battery is drained. Usually I set it on medium to warm the bed and low for sleeping or else it will roast you out. It is surprising how comfortable the trailer is, and how little it takes to warm it up.
Ahh, being in a wetter climate than I, can you tell me if it takes the dampish feel out?
stumphugger
Images: 76
Users browsing this forum: Google [Bot] and 3 guests
