Tumbleweed_Tex wrote:I haven't been able to figure how to get a sawsall and blade into position to cut between the studs and wall boards. If you look head-on at the business end of the sawsall, the blade is such that you can't flush cut, where the multi-tool blade allows flush cutting.
The thought of hole cutting the nails and then plugging the holes has entered my mind, but that's my last resort.
Wolffarmer wrote:Just some smart a&&^%d ones. Like sell the house to some lumberjocks and walk away.
Man that sure would be some nice wood, if it could still be worked.
Good luck
Randy
Tumbleweed_Tex wrote:I will try the sawsall this weekend...but I shudder to think what the back side of those boards will look like.
Maybe...
Meanwhile, keep thinkin...
Woodstramp wrote:Have no tool suggestions above your own and those already offered...but, you mentioned that the lumber is extremely dry and brittle.
Maybe you could try another angle....buy or borrow a couple of room humidifiers, turn them on, seal the room and let wood soak up some long spent moisture. Might allow enough pliability to remove with standard wrecking bar? Then restack and allow to dry again.
Pine has very resonous summer wood layers but the spring wood is very porous, pithy and hydroscopic.
Users browsing this forum: Google [Bot] and 7 guests
