anchor floor to trailer
Postby ardan » Sun Nov 27, 2011 9:38 pm
Hi All,
I know that this must seem a silly question but I am close to starting my first build and I cannot seem to find the answer to this question....
Do most people bolt the floor to the trailer with "U bolts" or do they drill a hole in the trailer beam and use a standard Bolt..?
Thanks
ardan
ardan
Images: 27
Postby Oldragbaggers » Sun Nov 27, 2011 9:51 pm
I used standard bolts. I have 2x4's down both sides of my trailer, they each have five 3/8" bolts and lots of PL Premium glue. The floor is screwed into them every 8" and also bolted to the frame with two 3/8" bolts on both the front and the rear (more glue too.)
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Juneaudave » Sun Nov 27, 2011 10:05 pm
Another popular way to fasten the deck to the trailer is to use trailer floor screws like these from ABCTrailer Parts. They can be found at any number of places.
To use trailer floor screws, you simply drill a pilot hole through your floor into the steel and sink them in.
Juneaudave
Images: 380
Thanks
Postby ardan » Sun Nov 27, 2011 10:09 pm
Thanks for the quick answers and the Pictures........
I don't think I would try this build without the folks on this forum....
Thanks Again...
Ardan
ardan
Images: 27
Postby Forrest747 » Sun Nov 27, 2011 11:10 pm
What I did about every two feet drilled holes in the metal frame and then into the 2X4 to match them up. Countersunk the bolts and then framed the floor to match the metal. Applied locking washers and locktight on the underside. they are 3/8th bolts. a little overkill but they were free so why not.
Forrest747
Cowbell Donating Member
Images: 447
Postby Deryk the Pirate » Sun Nov 27, 2011 11:22 pm
I dont have a great picture of mine at that stage but when I stretched my frame to 4x10 I mounted a cedar 2x4x10 oneach side, about 7 1/2" bolts on each side then the floor is screwed down to it in many places. I also have 2 cedar 2x4's across the width that the floor is also screwed to. Im hopein that holds up lol.
oh and i did turn the sideways one narrow side up.
Deryk the Pirate
Images: 158
Postby mike93lx » Thu Dec 01, 2011 6:14 pm
Oldragbaggers wrote:I used standard bolts. I have 2x4's down both sides of my trailer, they each have five 3/8" bolts and lots of PL Premium glue. The floor is screwed into them every 8" and also bolted to the frame with two 3/8" bolts on both the front and the rear (more glue too.)
Becky, thanks for sharing those pictures. That give a lot of area to glue & screw the side walls to.
mike93lx
Postby gregp136 » Thu Dec 01, 2011 10:48 pm
We completed the floor, using 1/2 inch plywood on 2x2s and just used standard bolts to attach it to the frame.
Greg(and Laurie)
gregp136
Images: 100
