air conditioner thoughts?
Postby donnie99 » Sat Jan 14, 2012 10:18 am
whats everyones opinion on air conditioner set up for a 5x8 beroy. mount a 5000btu in galley. or go with the hacked 5000 btu split system like i have seen people do on here?
Donnie
donnie99
Postby mvperini » Sat Jan 14, 2012 11:19 am
there are more options for A/C for a teardrop just do a search. here is what i did on my 47 kenskill. i mounted a removable table on one of the doors that holds a small ac unit. I did a step by step instructions with pictures here on the forum
mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby Roly Nelson » Sat Jan 14, 2012 2:36 pm
I simply installed an 85 dollar Home Depot window AC unit within my tongue box. I cut a water-proof hole from tongue box thru the front wall of the TD for the cool air to enter, with a scoop diverting the air upward and a return air opening below, aligned with AC supply and return vents in the AC unit. Just too keep things ventilated, I added a grille in the front of the box to discharge warm compressor air. I have had no problems with moisture or water from condinsation within the tongue box. This set up works so well, I believe it would freeze ice on the windows, if left on with the windows, doors and roof vents closed...... :-)
8) :? :thumbsup: Roly, So Cal TD designer, builder and user!
Roly Nelson
L'il Ol' Woody Builder
Postby emiller » Sat Jan 14, 2012 2:40 pm
Here is Arizona it is dryer so I just use a evap cooler. I tried the a/c deal first with a pet cool then window unit and found it to be more of a hassle and took up a lot of space. And I rather head where its cooler to camp when its hot.
emiller
Images: 157
Postby Woodstramp » Sat Jan 14, 2012 4:16 pm
You are in Georgia.....I'm next door in Bama.....if you want to warm weather camp I'd go for it. I embedded one in our TTT and love it.
Look up a fellow here called Casey Dog. On the last build he did about one of the best/simplest AC installs I've seen.
For viewing our different methods, check page 4 of our build:
http://tnttt.com/viewto ... c&start=45
And page 5:
http://tnttt.com/viewto ... c&start=60
Another neat way to use a cheap AC is the way a member named Parnold did his on his tear. Search his builds. He basically set it up where the unit is
outside and just ducted into a window. That way he doesn't carry the extra weight when the AC is not needed. Saves space too.
Woodstramp
Postby CliffinGA » Sun Jan 15, 2012 12:27 am
Hey Donnie lots of different ways to do it. I've done a few different ones on my lil tear drop from making a door piece that the a/c was left in and I just left the door on the drivers side open and tied back and had some twist that held the a/c door in place from the inside. that worked great but the a/c stuck in too far. Tied a different approach on the next couple of trips using a/c ducting and duct tape , uh we are in GA!
Used a piece of a/c sheet metal with a 6" starter collar, 6" ducting and a square to round duct piece tape to the 5000 btu a/c. Never got hot that was for sure!
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby Shadow Catcher » Sun Jan 15, 2012 7:50 am
Ours works beautifully.
