Best trailer to use?
Postby mikencfl65 » Wed Apr 18, 2012 12:15 pm
What would be the best 4x8 trailer to use?
The one sold at Harbor Freight or Tractor Supply?
I see a the Harbor Freight trailer is about 50.00 cheaper.
Anyone have there thought?
This will be my first build.
Thank you
mikencfl65
Re: Best trailer to use?
Postby grant whipp » Wed Apr 18, 2012 1:03 pm
Ummm ... the one from Tractor Supply is made in the USA, if I'm not mistaken, using readily available bearings & races and US DOT-approved coupler. I'd go with that one!
Good Luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby campmaster-k » Wed Apr 18, 2012 1:37 pm
I also have looked at the Tractor Supply trailer and I think it will be the one I buy for my next build. Way better.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby mikencfl65 » Wed Apr 18, 2012 2:03 pm
Is a shame tractor supply does not sell a 5x8
Hard to get a double mattress in a 4x8
Thanks for the input!
mikencfl65
Postby 2bits » Wed Apr 18, 2012 2:07 pm
mikencfl65 wrote:Is a shame tractor supply does not sell a 5x8
You can build up over the wheels and make the body 5' wide :beer:
Thomas
2bits
2bit Member
Postby ioan » Wed Apr 18, 2012 5:26 pm
ioan
Postby TBuilder » Thu Apr 19, 2012 7:01 am
I had my 5x8 trailer frame built by a local trailer shop, and it cost the same as the Northern Tool one.
The benefits being:
* welded frame
* custom gussets for bolting teardrop to the trailer, so I wouldn't need to make holes in the frame
* larger wheels/tires
* stronger axle
* no nagging feeling that the last pothole rattled a bolt loose
* support for local small businesses
TBuilder
Postby TBuilder » Thu Apr 19, 2012 8:00 am
My point is, if you're going to pony up the $500 anyway, the better value is with a custom one.
Sure you can make the HF/NT trailers as good as a custom welded one, but that's extra $ that could be used to buy wood etc.
TBuilder
