Window Clamp Ring screws?
Postby mikeschn » Thu May 03, 2012 6:35 pm
I bought some RV windows for my next weekender build. They came with clamp rings, but no screws. Does anyone know what kind of screws to use?
Here's the type of window I have:
Images: 479
Re: Window Clamp Ring screws?
Postby Martiangod » Thu May 03, 2012 6:46 pm
Just # 8 panhead screws, you will have to determine the length once you wall is built so you know the thickness of the wall. My build uses 2" screws
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Tom Kurth » Thu May 03, 2012 9:02 pm
Self-tapping screws make the task much easier.
Tom Kurth
Postby linuxmanxxx » Thu May 03, 2012 10:45 pm
I have the doors that have the same type rings. I almost herniated myself trying to get the phillips head self tapping screws to tap the groove and have found that lowes metal piercing screws are perfect and have a 1/4" hex head which makes much easier driving into the groove. Also the rings for the doors are set for 3/4" walls or flipped around is 1 1/4" My wall depth is 1 1/16 to 1 1/8 and the 3/4" side won't work at all as the ring won't seat on the wall. I flip it and get matching screen door trim for my interior and use it in the middle of the areas of the four sides to support the ring from collapsing and it works great that way with #8 1 1/2" piercing screws. Hope this helps and I've done 5 of these doors so far and promise thses screws are much easier than the self tapping ones.
linuxmanxxx
Images: 10
Postby jss06 » Fri May 04, 2012 7:33 am
My windows came the same way. I used self tapping screws and a cordless drill/bit driver. The screws went right in with no problems. My doors were slightly thinner than the widnows were set up for. Made a spacer out of some scrap 1/4" to fill the gap all the way around. Unless you look for it the spacer is not noticable.
jss06
Palladium Donating Member
Postby Lgboro » Sun May 06, 2012 3:26 pm
I just installed the same widows a week ago and they went in very easy. I believe I used a #8 also.
Lgboro
Images: 53
Postby mikeschn » Sun May 06, 2012 4:19 pm
Thanks for the info guys. #8 is what I'll try. It looks like there a couple different options to try!
Images: 479
Postby shil » Mon Jun 04, 2012 10:29 am
Where did you get these, if you don't mind me asking?
shil
Postby jss06 » Mon Jun 04, 2012 3:21 pm
I got mine on ebay. A reseller called Bottom Dollar Surplus.
jss06
Postby Jkester » Mon Jun 04, 2012 8:32 pm
John,
How wide are your walls? I will be installing my windows next week in 1-1/4" walls and it looks like my windows may need shims also. :NC
thanks,
James
He who loves instruction loves knowledge, but he who hates correction is stupid.
-- Proverbs 12:1
Our build journal is http://tnttt.com/viewtopic.php?f=50&t=50670
Jkester
Images: 55
Postby MudFlap » Sat Dec 26, 2020 5:54 pm
Here's a dumb question...
I'm installing some used windows that didn't come with screws. Thanks for the info on the correct type of screws.
163937
My question is: Do the screws just grab the side of the groove/channel, or do they penetrate the groove for extra holding power? The groove is so shallow that I can't imagine that option 'A' above is correct, but I thought I'd check to be sure.
If 'B' is the correct option, I'm guessing that it would be helpful to line up the trim ring and window on a work bench and drill pilot holes???
Thanks for any tips...
MudFlap
Postby featherliteCT1 » Sat Dec 26, 2020 7:03 pm
My window screws just grip the sides of the groove, like option A.
Last edited by featherliteCT1 on Sun Dec 27, 2020 11:28 am, edited 1 time in total.
featherliteCT1
Postby saltydawg » Sat Dec 26, 2020 7:19 pm
Mine are B.
Scott
Lost in Maryland
saltydawg
