Miriam C. wrote: or use battery powered everything. *(D cell type)
Miriam
Larwyn wrote:Seems to me that a person or object in contact with earth/ground which also comes in contact with the live wire would cause sufficient differential current to trip the GFCI.
GeorgeTelford wrote:The difference between live and neutral is what springs the GFCI (RCD) but if there is no earth/ground present then the GFCI will never ever trip, it cannot
GeorgeTelford wrote:Using that yellow portable unit is the same, its increasing the risk of being killed, there is no proper way to bond the conductive material of the camper to earth, its not meant for use in a camper.
GeorgeTelford wrote:Hi Bruce
You are completely and utterly wrong.
The link you posted shows exactly why you are totaly and utterly wrong.
The earth in the link is the ground beneath our feet, but you have already suggested using mains in a tear with no earth wire bonding or path to ground.
Remember saying that the yellow outdoor extension was a good idea? and now you can see why it isnt, No ground path in tear and or earth wire bonding.
Have we a real American electrician here, to explain it to Bruce? Its against regs over here and against code over there and an unecessesary danger anywhere.
