pmowers wrote:Don,
If you are still looking for a cover for the floor exhaust, I came across this this morning, and thought that it might just fit the bill. I think that I have seen it listed locally as well. It would normally be closed when the a/c is off, then the flap opens when the exhaust starts up.
http://www.amazon.com/Lambro-143W-Under-Eave-Vent/dp/B000H5PTSG/ref=sr_1_2?ie=UTF8&qid=1342196632&sr=8-2&keywords=soffit+vent
Sorry to hear about your tin.I ordered some e-track rings with free shipping from OR, and deckplate covers from FL with shipping charges at the same time. The rings were here in 3 days, the plates took 8, although the supplier was 2000 miles closer. It doesn't sound right that FedEx hasn't updated the tracking for over a week, unless it is one of those FedEx to US Snail deals, then I am not surprised. Have you had the BORG (big orange retail giant) put a trace on the package?
notoriouskelly wrote:Sorry about the delay, Don.
My trailer is on hold til I get it by welder Monday.
Thanks for the cooler tips- mine is identical and I see how the air goes in the front.
I may do something similar.
notoriouskelly wrote:Thanks for flagging that, Don.![]()
The front will hold a paper towel but the rear seems to have stronger draw, so now I know where to concentrate.
notoriouskelly wrote:I drained my A/C unit this morning; the past two days have been the most humid I've seen in Montana.
This morning 98% humidity on my weather station with no rain, so I've been keeping unit on.
I can see I'll install a drain tube to use in trailer so I don't have to manually empty the water.
re: generator- yes, a key factor in choosing which A/C to use was one that would run on my generator.
Good job on ditchin the rooftop at cost!
flboy wrote:notoriouskelly wrote:I drained my A/C unit this morning; the past two days have been the most humid I've seen in Montana.
Living in Florida, my AC would shut off almost every hour to two hours due to the humidity. I had to install a drain (drilled hole in floor to put drip hose through) to make it practical..
Users browsing this forum: markar and 9 guests
