by working on it » Sat Aug 25, 2012 10:02 pm
I'm intrigued with the Wiley Window. Looks too simple to me to be watertight, but then again, I've not seen one in person nor seen how tight the seal is. But, if it works for all of the people that've built them, and since Andrew (whose drawings/data I rely on) has added a simple twistlock that even I (a stillborn engineer) can understand, then that's what I'll use. There's always a complication in my plans though...I want to be able to take out the lexan/safety glass/bug screen and replace it with an A/C window unit (5k window shaker variety). I went to a lot of pains to seal the rear wall from the sleeping area, due to generator/gasoline/battery/cooking gear there, and don't wish to drill any holes there, much less put a permanent open area in that wall (even with the A/C vent closed, it's still open somewhat). I was resigned to my fate, "pull down the wall", until this subject was revived. My question...has anyone done this before? I can make the window the exact size to cover the A/C dictated/sized window opening, and seals for the A/C unit will be attached to the unit itself, not the opening. Only the lexan/safety glass/bug screen (undecided on material as yet) will have to be removed (along with its' own weatherstrip). Foresee any problems?
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
