Jim Marshall wrote:I got a question, I noticed that Jack used quite a few bolts to hold his fenders on. I didn't use near as many as he did, now am wondering if I should go back and add more. What would be the minimum number of bolts that should be used?
Chip wrote:Jim to get the slim fenders over the tires I had to mount them out away from the body about an inch and a half,,, I used a metal bracket on the front, the middle and one at the rear, welded to the fender and then two elevator bolts per bracket,,, If the fenders were wider than I would have just solid bolted to the body as you descrribed,,, skinny fenders called for alternate mounting
chipper
