I had a question with regard to my soon to be constructed solar (beer can) furnace and couldn't find it a fitting home.
Well anyway here is the question......
I was brain storming air flow and not being as smart as many of our engineer types I was kinda in a fog as to how to divide and equilize the pressurized air flow thru the solar furnace tubes.
Here are the parameters, the furnace is 29 wide by 87 tall that's 10 cans wide and 16 cans tall. There is an 1 1/2" hole in the bottom of each can and with the entire top cut out with a can opener the top is a 2" opening. The flow will be as in the drawing below. The unit will be fed with a small yet to be determined fan.
This being said I am trying to determine how to equalize the air flow thru the tubes. I am smart enough to know the air flow will take the path of least resistance and do not want 90% of the air flow to go thru the first 2 or 3 tubes. This would greatly reduce the effeciency and leave the heat in the last several tubes. In the picture I have added an inclined baffle that will raise the compression in the entrance chamber the further back the air flows. Am i off base here? My other thought was to let the entrance holes in the bottom support board get progressively larger as they step to the rear (left side). To me the inclined baffle make the most sense but does it work in actuality?
I would appreciate any fluid dynamics engineer type or perhaps an HVAC designers opinion and am open to any good ideas to make this little unit more effecient after all it's free heat and you all know I LOVE FREE !
