GPW wrote:From further reading ... "i think my second build was too high, so i destroyed the shell.” ...![]()
You girls are so Impulsive !!!
You know it’s a simple matter to add on to any foamie trailer ... Foam , being a homogenous material (no grain) ...you can add or cut out what you want , no harm done ... Say you have a too tall trailer , mark around the sides , and take out a “section" all around , dropping the height “X” number of inches ... add “reinforcing strips" , paint ... Done !!!
Too narrow , split it down the middle and add a center section in , making it Wider... ( you do have to make the floor wider for that ) ... Easy to make Longer too ... Anything !!! Just consider it as “home re-modeling” where you don’t tear down the house first ...
Ps. you couldn’t do that with wood without a Lot of Trouble ...
GPW wrote:Bonnie, for yours , fiberglass tape , for canvas covered trailers , canvas strips ... You did read all this huh ???
You probably need to clean the area to be painted with a de-greaser as epoxy tends to leave a waxy substance , which resists paint
