Lamination Tips and Tricks
Postby Micro469 » Mon Apr 03, 2006 8:30 pm
I was reading an American Woodworker and came across an article on Lminations. Thought you guys might be interested in a few points.
Using the right ply thickness
Radius .............. Ply thickness
2-4" ...................... 3/32"
4-8" ..................... 1/8"
8-12" ..................... 3/16"
12" or more .................... 1/4"
Compensate for Springback
FORMULA .............. R|final (n-1)/n=r|form
Example ............ A 5" radius, 10 ply lamination
5"(10-1)/10=45/10=4.5"
5"=project radius ......... 10=number of plys .......... 4.5=form radius
Hope thats clear...... ;)
John
Micro469
Images: 382
Postby dacrazyrn » Mon Apr 03, 2006 8:48 pm
...as mud.
dacrazyrn
Images: 74
Re: Lamination Tips and Tricks
Postby Mullet » Sat Apr 08, 2006 6:37 am
So, start with the correct ply thickness for the final radius you want and figure out how many plys you will use.
To get the radius for the form, you multiply the final radius by the number of plies minus one divided by the number of plies
For a 5 inch final radus, using ten plies (each of which must be 1/8" thick), you would do this to get the radius of the form for laminating:
5 x (10-1)/10 = 4.5
What I am wondering is whether this was for a circle, a half circle, etc.
edit, well, uh, more like a greater-than-a-half-circle intead of a circle.
Mullet
Postby Miriam C. » Sat Apr 08, 2006 11:02 am
Thanks for posting this. Does this mean if my radius is 24" (per lil dinner) then I just need 1/4 in ply in any combination?
Miriam
Edit: Or does it mean a 1/4" ply will bend to meet the radius???
