Anyone Build your own Fenders?
Postby PubUltraStar » Tue Feb 12, 2013 8:39 pm
I recently had the thought that since I'm building a woodie, that I'd like to build my own fenders as well. Using the same technique that you'd use building a cedar-strip kayak or canoe, you could use wood bending to shape a fender, and then fiberglass the end result. Since I'm having the templates for the side of my tear cut from a CNC machine, I was thinking of having him also cut templates for the fender as well. Then, it's steaming the wood, bending onto the mold, dry, and then move onto the next strip. Once all the strips are dry and conform to the new shape, fiberglass on the inside and outside with Epoxy, and voila! Of course this is much easier in my head. Just thought I'd throw it out there for discussion.
Mike.
There is always risk in being awesome!
http://www.diy-teardrop.com/
http://www.m2-photo.com
PubUltraStar
Re: Anyone Build your own Fenders?
Postby Dean in Ct. » Wed Feb 13, 2013 5:51 am
I built mine out of strips of plywood cut with the curve and glued up edgewise. I mostly used a 4" angle grinder for fairing. Then I laid a coat of fiberglass on the outside and more fairing. I did not finish them to a terribly high standard because truthfully I made them a little too small visually. I was coming from a motorcycle mindset where the front fender nearly rubs the front tire but travels with it. Quite different from a trailer. I may redesign and tr again or I may save that for build #2! Good luck. It's very doable.
There's a few pictures of their construction here
viewtopic.php?f=50&t=49965
Dean
Dean in Ct.
Images: 32
Postby MeelisV » Wed Feb 13, 2013 12:20 pm
There is some pics how i made my fiberglass fenders what will move with axle
first mold
https://picasaweb.google.com/lh/photo/r ... directlink
next mold - negative
https://picasaweb.google.com/lh/photo/B ... directlink
fender
https://picasaweb.google.com/lh/photo/5 ... directlink
final product
https://picasaweb.google.com/lh/photo/m ... directlink
and frame under fender is like that (its first version and now have more rigid frame)
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Postby PubUltraStar » Wed Feb 13, 2013 12:38 pm
Wow, those are both great examples. Thanks for the pics and info.
PubUltraStar
Postby Bogo » Wed Feb 13, 2013 11:29 pm
I'd line the fenders with well attached steel or aluminum to contain any shredded tires. Yeah, hopefully you'll notice the flat before it delaminates, but with my luck on small lightweight trailers, I don't seam to notice one going flat until it delaminates. That tire thread flailing around can do allot of damage fast. I've had a conventionally mounted steel fender ripped off by a shredded tire. I then mounted the replacement fender with a couple more brackets and it stayed on, but the brackets bent, when I had the next delamination. It's kind of funny, I can notice a tire just 3 lbs low on one of my trucks, but on a trailer I seam to have no sense of one going flat. I guess not enough change in handling makes it through to the TV for me to notice.
Bogo
Images: 39
