Stainless Steel Micro-Airstream behind motorcycle
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby KCStudly » Fri Mar 01, 2013 4:05 pm
Good job! :thumbsup:
Postby ST1100 » Fri Mar 01, 2013 4:57 pm
Next I have to go to the authorities with my TÜV vehicle inspection report and get an official seal,
that recognizes my right to pull that trailer everywhere with my license plate.
Then I have never again to show up with it at any authorities.
Next steps will be to build the alu boxes under the deck for gear and cloth and replace the wooden deck with a 1.5 mm aluminum sheet (my birthday gift).
And then give the utility trailer the rounded shape of an micro-airstream, with a 10 inch high skirt from stainless steel all around.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
23: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 02, 2013 12:12 pm
Here the first picture after the first ride.
I do not see the trailer in the mirrors and I do not feel the 60 kg while driving.
PERFECT !
1977 Eriba Troll
ST1100
Images: 199
Postby KCStudly » Sat Mar 02, 2013 7:24 pm
Your goal is becoming a reality. :thumbsup:
Keep up the good work.
24: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 03, 2013 1:22 pm
Okay - removed the plywood that was only to get my title and made a pattern to cut the aluminum sheet, that will build my full size deck.
1977 Eriba Troll
ST1100
Images: 199
25: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 03, 2013 1:23 pm
Then cut the corners with a jigsaw and made a fitting test.
1977 Eriba Troll
ST1100
Images: 199
26: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 03, 2013 2:27 pm
Last step for today, cut from every sheet a stripe 140 x 14.3 cm that I will rivet at the outside of the middle section of my frame to make it stronger.
Into that two stripes I will drill the holes for the rivets within the next days
The hole in the middle of the deck will be closed by two doors, one for a baggage compartment for cloth, the other for a step in box for my feet, when I'm sitting inside the trailer.
1977 Eriba Troll
ST1100
Images: 199
Re: 23: Stainless Steel Micro-Airstream behind motorcycle
Postby S. Heisley » Sun Mar 03, 2013 2:33 pm
ST1100 wrote:Here the first picture after the first ride.
PERFECT !
Postby harleykamper » Sun Mar 03, 2013 11:50 pm
Hey you're coming along nicely! I think your build is much more upscale than mine! It looks great! Any idea of the projected weight?
Paul & Marilyn Moon
2008 anniversary edition Harley Davidson ElectraGlide Ultra Classic
Kustom KlamShell tent Trailer. (In build now)
The ClamShell Tent Trailer Build Journal viewtopic.php?f=50&t=54531
harleykamper
Images: 206
Postby ST1100 » Mon Mar 04, 2013 1:53 am
harleykamper wrote:Any idea of the projected weight?
Thank you !
Chassis and body together should not be heavier than 130 kg (287 lb)
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Mon Mar 04, 2013 8:10 am
Ordered a set of 24 clecos with pliers at aircraft spruce and the first sheet of stainless steel plus 24 meters of aluminum tubing at my local steel dealer.
:D Tom
1977 Eriba Troll
ST1100
Images: 199
Postby RandyG » Mon Mar 04, 2013 5:01 pm
Oooo clecos, invaluable tool! One thing about that diamond plate with rivets, getting your rivets to sit flush with the ridges is a pain in the... You can either plan ahead and place all your rivets, or bolts, in between the ridges or shave the ridges down. If it were me I would drill between them. I'm sure you may have thought of that but just some advice doesn't hurt. Lookin' good so far and good luck!
Randy
RandyG
Images: 115
Postby sportxlh » Mon Mar 04, 2013 5:06 pm
Very cool build: I love folks creating things in metal like you are. Good luck
sportxlh
Postby ST1100 » Tue Mar 05, 2013 3:46 am
Today at 07:55 a.m. I got my official "Betriebserlaubnis" (approval to use) to tow my trailer on the streets .
Now the real fun begins !
:D
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Tue Mar 05, 2013 5:16 pm
Today I drilled 94 holes into my support sheets, that I will rivet on the outside of my frame to make it more solid.
Deburring both sides makes 188 times !
1977 Eriba Troll
ST1100
Images: 199
