rbeemer wrote:If you are painting or siding(aluminum), I would not worry about the fitting 2 peices of plywood for the sides because you can spline the plywood together and fiberglass and epoxy the joint and no one will know.
Caradoc wrote:To make this very clear: "Instead of being fitted in their intended place, the two cross members from the centre of the trailer are fitted longitudinally, inside the main side rails. One inside each siderail. This converts the folding trailer into a rigid trailer. Install a pine cross member in place of the channel cross members." [Generic Benroy Plans]
Miriam C. wrote:First, once you put the floor on the trailer it isn't going to fold up. .........................
Have fun.
Caradoc wrote:..............I want to get going, but before I tear the trailer apart again, I want to take it to the DMV to get licensed. I figured it's easier to do it now as it's still in its stock form, rather than explain all of the changes I've made.
--Lance
donkro wrote:After reading this thread and others, is it really necessary to do anything to the trailer to make it rigid? Is it loose or something when put together properly? I would think that after bolting the floor down the trailer should be pretty rigid. Has anyone just used the stock folding trailer with no mods and had any problems with it?
Caradoc wrote:Pictures will be soon.
Caradoc wrote:Despite all of my reading, I missed the key sentence.
