Door Question
Door Question
Postby aggie79 » Wed Aug 13, 2008 5:29 pm
What finished clearances should be used on the exterior doors?
I was thinking 1/8" to 3/16" on the handset side and top and bottom and whatever is necessary on the hinge side (hinge thickness if I use a piano hinge or ~ 1/8" if using torpedo/lift-off hinge.)
Postby mikeschn » Wed Aug 13, 2008 5:34 pm
The correct answer is whatever looks good.
If you can see the gap from the outside, a smaller gap is better. 1/16 to 3/32.
If you are going to use t molding on the outside, then 1/8" or more is fine.
If memory serves me correctly, this was about 3/32.
Postby Dean_A » Wed Aug 13, 2008 8:07 pm
That's about what I have on my doors. I used the t-molding method, as it covers up my marginal carpentry skills. :lol:
Dean_A
Images: 55
Postby Von Pook » Sat Aug 23, 2008 12:33 pm
How do you keep the doors water tight? What keeps the water from being forced into the interior while traveling?
Eric, the camping sound guy
Von Pook
Images: 10
Postby Dean_A » Mon Aug 25, 2008 1:50 pm
Von Pook wrote:How do you keep the doors water tight? What keeps the water from being forced into the interior while traveling?
Weather stripping.
Dean_A
Images: 55
