MetalMiner wrote:Newbie here! I have just finished building my first teardrop and also just discovered the forum. I wish I had found it sooner - I probably would have avoided a couple of pit falls - Oh well!
Question - I have an aluminum skin and I used GE Silicone II caulk on the trim. I am now having a devil of the time trying to remove the excess! I have been using Lacquer Thinner but it just seems to smear a film over a larger area.
Does anyone have any tips to remove the caulk film?
Steve_Cox wrote:MetalMiner wrote:Newbie here! I have just finished building my first teardrop and also just discovered the forum. I wish I had found it sooner - I probably would have avoided a couple of pit falls - Oh well!
MM,
Welcome to the forum. Glad you found us.
There is almost nothing that removes silicone after it sets up. You might try naptha to get rid of the film. Ace Hardware has something called MCKANICA SILICONE CAULK REMOVER GEL. I've never tried the Ace product myself. I usually use a razor blade, dry paper towels and lots of rubbing.
MetalMiner wrote:Thanks for all the advice. I will try one at a time until the caulk is gone!
By the way - I finally got to camp the first time with my teardrop (took 2 years to make). Boy was that nice! It is great when you find out that the things you "made your best guess at" really worked!
I wish I had known about the forum while I was building it!
