Carpet Interiors
Carpet Interiors
Postby BigAl » Mon Jan 11, 2010 12:03 pm
Hi Folks, I am thinking of fitting the inside of my trailer walls/ceiling with white carpet. I was going to put vinyl on the floor.
On the 'for' side it seems to be quick to apply, cheap, have a good finish, heat and sound insulating and comfortable.
On the 'against' side it might be a moisture trap.
Is there anybody out there with relevant experience that can advise me?
Kind Regards, BigAl.
Build Journal on T&TTT
BigAl
Images: 29
Postby Juneaudave » Mon Jan 11, 2010 12:10 pm
I used marine hull liner opn the inside roof oof my trailer. I'm not sure there are any downsides that I have noticed, and this stuff doesn't really seem like a moisture trap...Dave
Juneaudave
Images: 380
Headliner
Postby eamarquardt » Mon Jan 11, 2010 12:39 pm
Years ago I used carpet as a headliner in a VW van I owned. Worked fine and had no problems.
Gus
eamarquardt
Images: 150
Postby planovet » Mon Jan 11, 2010 12:47 pm
Juneaudave wrote:I used marine hull liner opn the inside roof oof my trailer. I'm not sure there are any downsides that I have noticed, and this stuff doesn't really seem like a moisture trap...Dave
Same here only I used it on my walls. Very satisfied. :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Re: Carpet Interiors
Postby Classic Finn » Mon Jan 11, 2010 1:12 pm
BigAl wrote:Hi Folks, I am thinking of fitting the inside of my trailer walls/ceiling with white carpet. I was going to put vinyl on the floor.
Al as the folks suggested use Marine Hul liner or Marine Carpet. Just because its cheap and quick dont fall for that in my opinion, due to the possibility of moisture being trapped under causing mold and mildew.
The Hulliner is what I also recommend for the usage. You wont be sorry.
Classic Finn
Midnight Sun Voyager
Images: 146
Postby BigAl » Mon Jan 11, 2010 2:35 pm
Hi guys, I am glad that I asked. I found a supplier in the UK but it's pricey at $65 sq.yard.
BigAl
Images: 29
Postby bohemian » Mon Jan 11, 2010 8:34 pm
If you gentlemen don't mind could you tell me what you used for glue to attach the carpet to the walls. And how would that stuff you used work for direct contact with Aluminum? Wayne
bohemian
Images: 233
Postby planovet » Tue Jan 12, 2010 9:27 am
You can use either of these products: Image Image
I used a light web covering buildup (on both sides). You have to be careful to not overdo it to prevent over saturating the material and having bleed it through. I put mine down over wood but it should stick to aluminum also.
ImageMark (& Cindi)
planovet
The Cat Man
Postby greekspeedoman » Tue Jan 12, 2010 7:53 pm
I used carpet in the Jpod headliner for the exact same reasons. here are a few pics of my process. More info on my website.
greekspeedoman
Postby Classic Finn » Tue Jan 12, 2010 8:06 pm
planovet wrote:You can use either of these products: Image Image
I used basically the same 3M Glue as above. And yes it does stick to aluminum. ;)
Classic Finn
Images: 146
