I'll jump in here with my two cents.
I think a computer power supply would make a great converter if you were willing to make the modifications, which would require a little web research and a multimeter for testing and confirmation. pretty easy to provide a switch to turn it on and off. If I remember of hand, you have to short out two of the pins to actually turn it on even if it has the external switch turned on.
You should find one that has a single 12v rail. They can come with multiple 12v rails and each rails will split off the total 12v rating.
You can find computer power supplies with 80% and higher efficiency ratings.
You can find smart power supplies that have automatic fans, that adjust the cooling fan to the temp.
I don't recommend a fanless one It is actually depending on both the convection and case fans a computer usually has by default.
Provide the airspace, intake and exhaust it requires for cooling.
A nice advantage is that you can also tap into the 5v rail and power up a few USB ports in your rig if your so tech savvy
I have actually gone back and forth a few times about using one for mine and still might make the jump.
http://www.newegg.com is a great source for computer part and more...
