color of cargo trailer
Postby pete42 » Tue Mar 23, 2010 10:18 pm
I am this close to ordering my new cargo trailer R&R 7X12 vnose.
Now one of the things is what color?
I like white, light gray or red then I see a moroon one and I like them also.
I would like to know what color trailer you have thanks
1) white
2) red
3)light gray
4) maroon
5) other?
pete42
Postby digimark » Tue Mar 23, 2010 10:45 pm
What color is your tow vehicle (TV)?
-- Gary Goldberg/Chesapeake Beach, MD/KA3ZYW
-- http://www.digimark.net/og/
digimark
Images: 40
Postby 8ball_99 » Tue Mar 23, 2010 11:20 pm
If you notice pretty much Every RV on the market is white or off white.. Reason is heat. When I was looking at Cargo trailers and told them I was going to camp in it. First thing out of every dealers mouth was I better stick to white or maybe a light grey. But they stressed white would be much cooler.
8ball_99
Postby Ageless » Tue Mar 23, 2010 11:59 pm
Most important part is the roof. That is total sun exposed. Keep it light. Stay with light coloured sidewalls. BTW; grey will soak heat almost as bad as black
Ageless
Postby bc toys » Wed Mar 24, 2010 8:57 am
mine is silver to match my jeep :thumbsup:
bc toys
Images: 42
Postby roadinspector » Wed Mar 24, 2010 10:41 pm
I check the external side skin temperature with an infrared temperature gun on a sunny day around noon. Both were side by side in direct sun light. Atmospheric temp was 65. White temp was 88 and the black was 118. 30 degrees difference is enough to convince me.
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby pete42 » Thu Mar 25, 2010 8:17 am
Thanks for the replies My truck is white and a white cargo hauler makes a lot of sense.
I am on disibility retirement with fixed income so I want to do this right the first and last time.
I think white with some decals or belly stripes would make it look better than all white.
it will have windows and rv style door.
again thanks for replies white it is.
pete42
Postby 8ball_99 » Thu Mar 25, 2010 10:13 am
roadinspector wrote:I check the external side skin temperature with an infrared temperature gun on a sunny day around noon. Both were side by side in direct sun light. Atmospheric temp was 65. White temp was 88 and the black was 118. 30 degrees difference is enough to convince me.
Holy smokes.. I knew there would be a difference but thats Huge. 118 surface temp on a 65 degree day. Sounds like a solar oven!!
8ball_99
Postby mdvaden » Fri Mar 26, 2010 12:40 am
I got a royal blue, just because it was already on the lot and I liked it. After a couple of years, I still like blue better than any other color. Maroon would be second color choice.
But the dark colors are warmer in sun. And I'd probably get white next time around. Although, with insulation added, it may not be as big a deal. Especially for me, since I camp near the coast most of the time where its 65 degrees most times, or less.
mdvaden
Color
Postby mcbalmer » Mon Apr 05, 2010 12:42 pm
I'm in the final stages of research for a cargo trailer and have a 6x12 v-nose that I'm considering. It is BLACK and at first I was concerned but after thinking about where I'll be using it (Alaska) I'm now confused. Will I want the extra heat or with the extended summer sun will it be too much. Any imput would be great!
mcbalmer
Postby Ageless » Mon Apr 05, 2010 2:05 pm
You have to take into account the angle of the sun. Being far north; direct sun is at a much lower angle than a place like CA. Your 'direct' sun will be much less intense. You will get much less solar soaking.
Ageless
Postby pete42 » Mon Apr 05, 2010 3:13 pm
things are not going my way right now health problems.
I still have hopes of getting a cargo trailer some time.
pete42
Postby michiganflipper » Tue Apr 06, 2010 8:38 pm
Mine is black but I think the roof is the biggest issueso i'm going to put a white rubber roof on this summer
michiganflipper
