To me having a trailer that can carry weight then adding a floor on top does not make sense.
I am building a large foamie (hopefully) around 28' long. And want it to be strong and light. As the trailer often seems to be the heaviest part I am thinking of ways to make it lighter and strong as well
I am thinking double axle with brakes, this would have angle iron on top of the axles, then 2 angle iron going from the axle up in a triangle to the hitch. Basically an A shape all-together.
Then no real metal framework. 1x4 or 1x6 framework, running the length of the trailer 18'. Filled with foam (want it for winter insulation anyway) and skinned on top and bottom with 1/4" ply. The do undercoating or bed-liner on the underside. Basically a big torsion box, bolted to the angle iron on the axles.
Could make the trailer out of angle iron and flat iron with styro filling it in and skin top & Bottom. But it would be heavier, costlier and more difficult.
Any thoughts on this?
