daveesl77 wrote:I have a 20"+ wide space that I use for cabinets and ductwork. Pull those out, install bunk bed and voila, room for 4, with floor space too.
dave
pchast wrote:IMHO... Do yourself a favor and run a ground wire to each light.
daveesl77 wrote:On the wiring, absolutely run ground and power wires to each component. Now, what I did was to create junction points at different areas of the trailer. Meaning "circuit A" is for interior lights, so I run a single 12 ga. feed ( + and - ) to 2 terminal strips ( one+, one- ) near where I planned to split off for the individual lights. I have an overhead LED strip, a small "reading" led light behind the head of each bed side, a small LED and an underbed LED. All are individually switched and 2 are remote controlled. So, from the junction points I can run much smaller wires to the LEDs, since they have very low amperage draws. This system is repeated for all circuits, both 12v and 120v.
dave
Users browsing this forum: No registered users and 41 guests
