RunnerDuck wrote:I have a Dometic CF-50 12 Volt / 120 Volt refrigerator and I'm wondering what would be the most efficient, running it off a a 12 V to 120 V converter or straight off of 12 V. The spec sheet doesn't seem to distinguish between the power consumption from either source, it's always 7 AMP.
I'm getting ready to wire up my TD and just not sure if I should wire it up to always run off the converter or 120 V when on shore power and 12 V when on the battery or wire it up to always run 120 V off of the converter.
Now the question is, how heavy of wire should I use for the 12V to the refrigerator over fifteen feet? I currently have 14 AWG.
GuitarPhotog wrote:It would make sense to me to set up a switch so you can run it on 120 VAC when you have shore power and 12 VDC when you don't.
<Chas>
