Aluminum composite teardrop
Postby bobwhite215 » Wed Oct 05, 2016 9:12 pm
Been reading everything I can find on teardrops the last few weeks, and am finally getting ready to start my build. Should be going to pick up my frame tomorrow.
Will be about a 5x9, with rear galley. Going to build a false floor to store our hammock stands.
Walls are going to be a 3 layer sandwich. 3/4" plywood skeleton, with foam insulation. Outer layer will be 3mm ACM, and inner skin will be tongue and groove pine paneling. The pine is 3/4" thick, but will probably plane it down to 1/2".
I've picked up lots of great ideas here, so thanks in advance to everybody whose ideas I am about to steal.
Wish me luck.
Sent from my SM-T817V using Tapatalk
bobwhite215
Re: Aluminum composite teardrop
Postby bobwhite215 » Wed Oct 05, 2016 9:32 pm
Here is profile that I found on line that we will be using as a starting point.
bobwhite215
Postby Mr. Lahey » Thu Oct 06, 2016 6:51 am
Nice sketch you have to get you started. Planning the build is way more than half the fun.
Hope you are able to find a trailer to build on. Get some sawdust flying soon!
Best of luck with the build
My teardrop camper build journal: http://www.tnttt.com/viewtopic.php?f=50&t=64721
Mr. Lahey
Postby KCStudly » Thu Oct 06, 2016 7:15 am
Yes, nice sketch! Welcome to the forums and good luck. :thumbsup:
Postby clip » Thu Oct 06, 2016 8:33 am
Ha, I started with the same sketch printed off a bunch of copies and flipped some so I could draw things on both sides, I left it at 10' but curled the backend in base is 9' over all length is 10'
Good luck, enjoy the journey
MS
clip
Postby bobwhite215 » Thu Oct 13, 2016 10:42 am
Well, the first part has arrived. All we need to do now is build a camper around it.
Sent from my XT1080 using Tapatalk
bobwhite215
Postby tony.latham » Thu Oct 13, 2016 12:04 pm
I googled it but didn't learn much.
What's it cost? What's the advantage? What's the core made out of?
Thanks, :thinking:
Postby MatthewWorks » Thu Oct 13, 2016 12:46 pm
Hey Bobwhite215 -
I think I'm using the ACM as well, at least for the sides. Need to test how much it'll bend for the top yet...
I'm looking at the economy ACM from Harbor sales: https://www.harborsales.net/tabid/130/D ... conomy+ACM
Tony, for me I wanted aluminum, but don't like the idea of oilcanning, especially with my oversized build. The aluminum is already bonded to a plastic core, so it'll be my outerskin, no plywood. About the same price as aluminum, less work, already meant for exterior use.
Matthew.
lost, but enjoying it so far.
18Jan2018:
total days in camper 92 (since Apr 2017)
camper has paid for itself with hotel/rental savings: 209%
MatthewWorks
Images: 30
Postby bobwhite215 » Thu Oct 13, 2016 12:50 pm
Aluminum Composite Material (ACM), is a material made of a plastic core, with finished aluminum faces bonded to both sides. It comes in various thicknesses, but I plan on using 3mm. It is sold under various brand names - dibond, maxmetal, and alupanel are a few.
The 3mm weighs about the same as 1/4" plywood. It is used primarily in the sign industry. I own a sign company, so it's easily available. I don't really know what it would retail for, but I get 4x8 sheets wholesale thru sign supply companies for about $35. It also comes in 4x10 and 5x10 sheets, which is what I will be using.
The big attraction for me, besides being something I'm used to, is that I get a clean, perfect finish in one step. I plan on vinyl wrapping the trailer. If I used traditional construction with wood exterior, I would still need to skin it in aluminum to get a good surface. With the ACM, its all done in one step. Should save time, money and weight.
Is it a perfect material for building a camper skin? Who knows, but I think it will work for me.
I should be picking up my frame next week, so the build will begin soon. I'll document it here along the way, so watch my progress here. I'll let you know how it works out.
bobwhite215
Postby bobwhite215 » Thu Oct 13, 2016 12:58 pm
Matthew - FYI, I think that it should bend well enough to use for your top. I've been playing with some scrap pieces, and doesn't seem to be a problem. I don't know where you are located, but you might be able to get some small scrap pieces to play with from a local sign shop.
bobwhite215
Postby MatthewWorks » Thu Oct 13, 2016 1:58 pm
Cool! That sounds exciting.
We have some pieces at home, my wife uses it for a drawing substrate in some of her artwork. Just put it together in my head a few days ago, but we've been on the road a week. Getting home in a few hours, going to experiment a bit.
Out of curiosity, are you planning on leaving it white? Out of stubbornness, I want the aluminum to show. Planning on doing some sanding/stripping tests this weejend.
Matthew.
18Jan2018:
MatthewWorks
Images: 30
Postby bobwhite215 » Thu Oct 13, 2016 2:31 pm
I think we are going to go with an old school Shasta camper look. Will do a turquoise color in the bottom (with vinyl), and leave the upper half white.
bobwhite215
Postby bobwhite215 » Thu Oct 13, 2016 2:34 pm
Matthew - you can get material in other colors than white, but more expensive. Also not sure if it comes in the oversize sheets.
bobwhite215
Postby dogscats » Thu Oct 13, 2016 2:51 pm
How do you plan to seal the ends? So the sun dose not eat the plastic core. Thanks
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby bobwhite215 » Thu Oct 13, 2016 3:03 pm
The ends will all be covered by aluminum trim molding. But even if they were not, I don't think it would be an issue. We use this material for signs. They sit outside for years and years with no protection. the core is an ldpe, which is not terribly uv resistant by itself, but we don't see issues in sign faces, so I'm assuming it is uv stabilized.
bobwhite215
