by kayakrguy » Fri May 12, 2006 4:23 pm
Folks,
To make a long story short, we took the Red Trailer out for a spin today--followed us everywhere! <g> It tracked well, and the car's new hitch worked well. Did the secondary roads so we had lots of bounce to the ounce!
I extended the trailer to 10 feet when I inserted the cross rails into the side rails. I also had the inserts welded to the sides and I had another piece of 1/4 inch steel welded to the sides as well--across the two foot increase.
I also had the spring hangers welded, I didn't think the RT bolts were up to the sheer loads I was askiing them to bear with the extensions so I felt more comfortable with the welding.
I also centerd the axle 35" from the rear of the frame so that tongue is going to stay down for sure! I had to insert a 2x4 cross beam for the additional length. I also had an extra 2B cross beam (RT owners know what I mean) because when I got my kit home and started finally (last Saturday) to build, I discovered I had no 2A beam--which is the front cross rail that the tow bar attaches to.
I called RT and Paul had a 2A to me the next day, just as he said. In terms of customer service they are A+ though I am not thrilled with having a Red China product. Anyhow, that is how I got the extra 2B rail.
So far I have only had to buy a cheap HF angle grinder and 3 or 4 drill bits.
For the floor, I will probably use 1/2 inch ply, and will piece it together from 4x8's using caulk between the joints, using outdoor latex on the floor bottom and covering with that pink stuff. <G>
Any advice, warnings, lessons, or smart things I should do please send them along. This board is great place for learning. I think it's capacity for teaching is amazing,
Ciao.
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
