Quoting a post in Chrome loses smilies
Threads about the forum, forum software, forum features, etc
Postby capnTelescope » Sun Aug 17, 2014 12:33 pm
Somewhere in the middle of my build journal, I switched from Firefox to Chrome. Since then, I've noticed that when I quote part of a post, I lose the smilies. :(
Is this a quirk of Chrome, or do I need to change a setting?
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Re: Quoting a post loses smilies
Postby capnTelescope » Sun Aug 17, 2014 12:34 pm
For Example:
capnTelescope wrote:... I lose the smilies.
Brad
capnTelescope
Images: 368
Postby capnTelescope » Sun Aug 17, 2014 12:38 pm
OTOH, if I quote the whole post, everything's OK:
capnTelescope wrote:Somewhere in the middle of my build journal, I switched from Firefox to Chrome. Since then, I've noticed that when I quote part of a post, I lose the smilies. :(
Brad
capnTelescope
Images: 368
Postby tony.latham » Sun Aug 17, 2014 2:47 pm
Well...... let's see what happens. I'm using Chrome on a Mac :) I just used a copy/paste to get your quote and smiley in.
TL
Postby Gage » Sun Aug 17, 2014 3:30 pm
capnTelescope wrote:OTOH, if I quote the whole post, everything's OK:
capnTelescope wrote: ....................I lose the smilies. :(
Strange, I don't get that result when I do just a part of a quote. :thinking: But who am I, I don't know anything? :o
Image Image Image
Gage
Images: 28
Postby teddy » Sun Aug 17, 2014 5:34 pm
capnTelescope wrote:I lose the smilies. :(
seems to be ok with Chrome.
teddy
Images: 187
Postby capnTelescope » Sun Aug 17, 2014 8:46 pm
Am I the only one in the whole wide world with this problem? :cry:
Brad
capnTelescope
Images: 368
Postby Gage » Sun Aug 17, 2014 10:57 pm
When you only do part of a quote, take your time and be sure you don't remove the coding for the smiley. Also check and be sure that you haven't checked the box to DISABLE SMILIES. :o
Image Image Image
Gage
Images: 28
Postby absolutsnwbrdr » Mon Aug 18, 2014 7:23 am
capnTelescope wrote:Am I the only one in the whole wide world with this problem? :cry:
Just pay attention to the text as you quote it and not accidentally delete the emoticon if you only intend to quote part of the post. The coding used to quote posts is built into the forum software and doesn't have anything to do with browser selection.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby mikeschn » Mon Aug 18, 2014 5:25 pm
Brad,
I just looked at your settings, and you do not have smilies turned off.
So I can only guess that when you did a partial quote you might have deleted the text that makes up the smilie...
for example a colon : and a parenthesis ) without a space in between makes a :)
Images: 479
Postby Gage » Mon Aug 18, 2014 6:38 pm
mikeschn wrote:Brad,
Mike, you can override that setting simply by checking the box that is provided below the main box that you enter you text listed under options.
EXAMPLE
:thinking:
Image Image Image
Gage
Images: 28
Postby Gage » Mon Aug 18, 2014 6:42 pm
It only affects that reply as noted here. I didn't check the box as I did in the last post. :o ...... ;)
Image Image Image
Gage
Images: 28
Postby mikeschn » Mon Aug 18, 2014 6:57 pm
That's correct Gage. I checked each of Brad's posts as well! :thumbsup:
But if you look at the text of Brad's post, there is no colon, and no parenthesis. Which leads me to believe he edited them out.
Images: 479
Postby capnTelescope » Mon Aug 18, 2014 10:22 pm
Gage wrote:When you only do part of a quote, take your time and be sure you don't remove the coding for the smiley. Also check and be sure that you haven't checked the box to DISABLE SMILIES.
I don't remove the coding, it didn't get put there in the first place. :(
I don't ever check disable smilies. In fact, I just had to really look carefully to find where. I like smilies. :)
absolutsnwbrdr wrote:Just pay attention to the text as you quote it and not accidentally delete the emoticon if you only intend to quote part of the post.
I've been paying extra attention, since this problem surfaced, to make sure I select the smilie before I quote. I'm selecting them. honest I am. :(
absolutsnwbrdr wrote:The coding used to quote posts is built into the forum software and doesn't have anything to do with browser selection.
That would seem to be correct, except in my case, apparently. :(
mikeschn wrote:So I can only guess that when you did a partial quote you might have deleted the text that makes up the smilie...
If the smiley code got deleted, I didn't do it :cry:
mikeschn wrote:But if you look at the text of Brad's post, there is no colon, and no parenthesis. Which leads me to believe he edited them out.
That would be a great practical joke to pull on y'all. :twisted: But I didn't do it. :cry:
If I select text that contains a smiley, copy and paste it into my text editor, the smiley code comes through.
If I try to quote the same selection, (sniffle) no smiley.
BTW, that's kinda strange. If I view the source of the page by using the browser function, it's an image tag that renders the smiley. But I don't recall seeing the smiley code. Maybe Chrome doesn't handle that somehow.
I can work around the problem, but it's an annoyance.
Brad
capnTelescope
Images: 368
Postby capnTelescope » Mon Aug 18, 2014 10:23 pm
I don't usually quote photos, so this is a test.
Brad
capnTelescope
Images: 368
Return to Threads about the forum!
