capnTelescope wrote:... I lose the smilies.
capnTelescope wrote:Somewhere in the middle of my build journal, I switched from Firefox to Chrome. Since then, I've noticed that when I quote part of a post, I lose the smilies.
Is this a quirk of Chrome, or do I need to change a setting?
Strange, I don't get that result when I do just a part of a quote. But who am I, I don't know anything?capnTelescope wrote:OTOH, if I quote the whole post, everything's OK:capnTelescope wrote: ....................I lose the smilies.
capnTelescope wrote:I lose the smilies.
capnTelescope wrote:Am I the only one in the whole wide world with this problem?
mikeschn wrote:Brad,
I just looked at your settings, and you do not have smilies turned off.
Gage wrote:When you only do part of a quote, take your time and be sure you don't remove the coding for the smiley. Also check and be sure that you haven't checked the box to DISABLE SMILIES.
absolutsnwbrdr wrote:Just pay attention to the text as you quote it and not accidentally delete the emoticon if you only intend to quote part of the post.
absolutsnwbrdr wrote:The coding used to quote posts is built into the forum software and doesn't have anything to do with browser selection.
mikeschn wrote:So I can only guess that when you did a partial quote you might have deleted the text that makes up the smilie...
for example a colon : and a parenthesis ) without a space in between makes a
mikeschn wrote:But if you look at the text of Brad's post, there is no colon, and no parenthesis. Which leads me to believe he edited them out.
Return to Threads about the forum!
