WalMart sells a flat 5 pin trailer plug which may be a solution for anyone wanting to charge the teardrop battery off the car's electrical system
The first 4 pins are the exact same as any standard 4 pin connector, so you can still plug all your other 4 pin trailers into the new 5 pin connector on your car . . . . the 5th pin (the +12 VDC one) just doesn't engage the 4 pin plug on the other trailers because there is no pin there
The 5th pin is labeled for backup lights . . . . but I'm going to use it to connect the tear battery to the car's 12 volt system so it will charge the tear battery as I drive - It should also serve to run my mini fridge sitting in the back of the car off the teardrop battery, so it will stay cool when the car isn't running without running the car battery dead
Don
