homemade redneck travel trailer type thing
Re: homemade redneck travel trailer type thing
Postby mckenney56 » Tue Mar 13, 2012 8:31 am
WOH! Looks like you'll have plenty of horse power to pull your camper.
mckenney56
Images: 129
Postby bradw18 » Tue Mar 13, 2012 7:56 pm
did a little welding today and got my 2x12s attached to the frame I built tomorrow I'm gonna start working on the floor
My supervisor
bradw18
Postby parnold » Tue Mar 13, 2012 8:08 pm
And the clock has started!! :applause: :applause:
Have you put more thought into what your doing on top of your floor?
parnold
Images: 302
Postby canned o minimum » Tue Mar 13, 2012 8:34 pm
With all that "lumber" you might hafta git a buildin permit ! Hope ya got a big tow vehicle to lug that building around.
canned o minimum
Postby bradw18 » Tue Mar 13, 2012 9:04 pm
Image. She's settin low due to a few ton of gravel
As far as the floor I'm planning on dropping down 6 inches and use plywood for my floor so I'll have 7 in of space between my floor and level with the 2x12s iv used. I'll post better pics tomorrow. She's gonna be heavy that's for sure hope I don't have to upgrade my axle. Trying to decide if I want to go with my pop out idea or maybe a wedge type camper
bradw18
Postby bradw18 » Tue Mar 13, 2012 9:07 pm
In the picture the 2x4 frame and 2x12s are upside the 2x12s lay on the frame of the boat trailer
bradw18
Postby Treeview » Tue Mar 13, 2012 9:12 pm
Why are you using the 2x12s laid flat on the outside like that?
Why not run 2x4 joists crossways then deck with plywood?
Lighter
Stronger
Rigid
Treeview
Images: 30
Postby bradw18 » Tue Mar 13, 2012 9:46 pm
This is the first camper-tent trailer iv ever built. I had most of this lumber laying around all ready also. It's gonna be very strong atleast. I have 12 6in long x 1/2in carriage bolts I'm gonna use to secure the frame to the trailer. And inside the 2x12s is 40 inches wide. That's how wide my walk space will be. I have to get a new circular saw blade tomorrow I tore my last blade up redoing the bathroom shower.
bradw18
Postby canned o minimum » Tue Mar 13, 2012 11:18 pm
Build on....
canned o minimum
Postby bradw18 » Wed Mar 14, 2012 6:43 pm
bradw18
Postby bradw18 » Fri Mar 16, 2012 7:57 pm
updates
started getting the sides on. shes really starting to come togeather if i do say so myself. i started to experiment with the hinge system. think i might have it figured out. either 3 or 4 hinges per side. trying to decide if i want to to a leg style support for the sides when there open or have 3 or 4 boards that will swing out when the sides are open and give the 2x4s support.
bradw18
Postby bradw18 » Fri Mar 16, 2012 8:05 pm
at this point i think its as heavy or just a little heavier then the out board motor was. in only 150 lbs and my buddy is probably 200 or so we can lift it up pretty easy still.
bradw18
Postby bradw18 » Sun Mar 18, 2012 4:24 pm
Makin progress
Gotta make the supports still and add some more bracing I probally have 5 or so inches between bottom of the flap and the ground. Might have to get a taller tire.
bradw18
Postby crumbruiser » Sun Mar 18, 2012 5:33 pm
I really like how you are using simple every day materials. I think the baby is gonna be big! Lots of room. :thumbsup:
Frank
I am not weird, I am a Limited Edition.
Facebook http://www.facebook.com/profile.php?id=100000303236631
crumbruiser
Images: 255
Postby bradw18 » Sun Mar 18, 2012 5:52 pm
Don't think its to big do you? Its 2 ft tall walls 5 foot body by 10 foot an when opened it's 10x10 gonna pick out a nice 10x10 tent for the top of it
bradw18
Users browsing this forum: Dan [Sac] and 5 guests
