Terry's TTT Garageable Standy Build modifications
Postby synaps3 » Sun Jun 19, 2011 10:34 pm
Awesome build. I'm jealous of your frame; it couldn't be more perfect. The sides look great too. :)
-- Dave
Build log: here
synaps3
Images: 254
Postby terryjones1 » Tue Jun 21, 2011 10:48 am
Shown below is a photo of the trial fit of right side wall.
The bottom 3" of the door way still has to be cut out.
Wall should be installed tomorrow.
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby aggie79 » Tue Jun 21, 2011 4:37 pm
Looking great Terry!
Keep up the good work.
Postby terryjones1 » Wed Jun 22, 2011 10:51 am
Shown below is a photo of the left wall to floor & fender connection.
In the lower left unpainted area & also, over the fender is where the bed will be.
The vertical connections thru the floor & the 1-1/2" x 1-1/2" cleats are 1/4" x 2-1/2" bolts.
The horizontal connections thru the cleats & into the wall are #12 x 2-1/2" cap screws.
Over the fenders, the connections thru the 5/8" x 1-1/2" cleat are #8 x 2-1/2 screws.
Also, everything has been epoxyed.
Shown below is another view.
The unpainted area to the right is where cabinet will be.
The unpainted area to the right is where a bench will be, which is part of the dinette/2nd bed.
terryjones1
Postby terryjones1 » Thu Jun 23, 2011 3:32 pm
Shown below is a photo of the right side wall of the trailer, which has been installed.
Again, the front & back walls are not installed.
They are only used for temporary support of the side walls.
Next is installation of front & back walls.
Also, I no longer need to use hoists or pulleys.
They have been taken down.
terryjones1
Postby terryjones1 » Sat Jun 25, 2011 4:23 pm
Shown below is a photo of the inside of rear wall.
It has been installed.
I have no room to do a photo of the outside of the rear wall.
The large hole is for the air conditioneer.
The small box to the right of the large hole, is for installation of a duplex recepticle for air conditioneer power.
Tomorrow, I install the front wall.
terryjones1
Postby Cliffmeister2000 » Sun Jun 26, 2011 3:17 am
It's starting to look like something, Terry! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby b.bodemer » Sun Jun 26, 2011 10:39 am
Terry,
This is a great build to follow!
Barb
b.bodemer
Images: 319
Postby terryjones1 » Sun Jun 26, 2011 11:53 am
Thanks for all the nice comments everyone!
Shown below is a photo of the inside of the front wall.
The wall has been installed.
The large hole is for the Fantastic Vent.
The small hole to the right of the large hole, is for installation of a duplex recepticle.
Shown below is a photo of the outside of the front wall.
The cardboard box on the right holds the Norcold DC0051 12 DCV refrigerator.
The cardboard box on the left holds the LG 7000 btu window air Conditioneer.
Next, I tackle installation of the roof.
terryjones1
Postby terryjones1 » Fri Jul 01, 2011 11:47 am
Shown below is a photo of the trailer with the center roof installed.
The front and back curved portion of the roof still needs to be installed.
Also, the outer plywood roof skin needs to be installed.
Shown below is a detail of how the roof is resting on the wall shelf.
There are thirteen 1" V x 3/4" H spars on the roof.
2-1/2" # 8 flathead Screws and epoxy were used to attach spars to the shelf on the walls.
The spars had previously been epoxyed to the 1/4" interior skin.
There is about 5'-11" of clearance, roof to floor, at the drop floor.
terryjones1
Postby terryjones1 » Fri Jul 08, 2011 10:01 am
Shown below is a photo of the inside of the rear roof curve.
Shown below is a photo of the inside of the front roof curve.
Shown below is a photo of the outside of the front roof curve.
The wires shown, at the curve, are for overhead lights.
The radius of the bend is 14".
The plywood used in the front and back bends is 3/16" "Bendy" plywood.
I had to match that up with the 1/4" plywood that I used for the middle roof and the front & back walls.
The spars used at the front and back bend area are 3/4" W x 1-1/8" H.
Shown below is a photo of roof mounting detail.
The spars are screwed & epoxyed to the side wall shelf.
The front and back edges of the curved panels are attached to the middle roof and the front and back walls with epoxy and screws every 6".
terryjones1
Postby matt987106 » Fri Jul 08, 2011 12:12 pm
very nice, this is a nice build
a little big for my needs though
matt987106
Postby aggie79 » Fri Jul 08, 2011 4:05 pm
Terry,
You almost have her all buttoned up. The curves turned out great! Soon, you can focus on the interior.
Take care,
Postby bdosborn » Fri Jul 08, 2011 5:39 pm
Terry,
Its always a big deal for me to get the roof on, I feel like it's finally a trailer. Your trailer is looking great!
Images: 777
Postby terryjones1 » Sat Jul 09, 2011 7:06 am
bdosborn wrote:Terry,
As I am sure that you noticed, I used about the same technique as you did to attach the roof to the walls. The center roof was easy. The front and back curves were more difficult.
terryjones1
Users browsing this forum: Google [Bot] and 26 guests
