Quick update..
Finished up the insulation and filled any gaps with spray foam:
Cut the excess spray foam flush with a jamb saw:
There's 2 pieces of insulation left to go in, behind the shower surround. The surround is cut to size and ready to be installed, so that should be completed during the week if I can catch a day without rain..
Meanwhile, I finished up the supply plumbing. Back under the bath sink is the city water connection:
The shower feed:
Water pump connection:
And finally the water heater. The 3 way valve and tee is a bypass for winterization:
Then finished up the inside wiring. The only thing left was the monitor panel and the power to the water pump:
Finished and tested plus some wiring cleanup:
I had procrastinated on the drains long enough, it was time to break out the glue and make it permanent. Did the grey tank stack, the shower drain and the bath sink drain:
Would have knocked out the galley sink as well, but ran into a problem with the sink tailpiece. The lip on the tailpiece is too thick so the nut can't get a good grip on the basket. Will pick up a new tailpiece this week and knock that out.
Finally, we got the roof decked with plywood:
The joints need to be sanded smooth as there is a slight bit of lippage in a couple of places. It looks really bad in the pictures but is less than 1/16" in reality. Then the excess needs trimmed with the router.
Unless something really goes wrong this week we should be hanging siding on Saturday.
- Frank
