Aluminum Frame RD
Re: Aluminum Frame RD
Postby RandyG » Thu Jun 13, 2013 4:32 pm
That's what I was looking for, a reflective material that is light and the insulating properties are a plus. I was going to find a small piece to test what type of glue works best and the strength of material. I may have to put a coating over it.
Randy
RandyG
Images: 115
Postby RandyG » Tue Jun 18, 2013 12:37 am
I got wood! :R And I got the floor rough cut and holes drilled for the screws. The frame still needs some work but I needed to see where the floor would lay to make progress and for motivational purposes. Pics coming soon.
Randy
RandyG
Images: 115
Postby RandyG » Tue Jun 18, 2013 10:05 am
108306108305108304108303
The big bolts go to the axle mount, it will get a plate to act like a washer.
Randy
RandyG
Images: 115
Postby KCStudly » Tue Jun 18, 2013 2:50 pm
You've reached a huge milestone!
Keep the nose to the grind wheel and... Get 'er done! :thumbsup:
Postby RandyG » Wed Jun 19, 2013 2:33 am
I found a hand rivet puller at a pawn shop today, but it does not work with cherry's. I hope it with pop some pull thru's. A hand cherry max gun will run about $500 so I think I will just barrow that from work. And the new compressor will assist, no more waiting for my little 3 gallon to charge.
Randy
RandyG
Images: 115
Postby RandyG » Thu Jun 27, 2013 3:04 am
Got a day off and alot of trailer time, I shot some more rivets, installed some nutplates, cut the (what Ron calls it) bow front, trimmed the floor to match the dado on the walls, and started drawing up my walls. Im trying to take my time while drawing theprofile but it is exciting being one step closer, one step closer to taking some sort of shape.
Randy
RandyG
Images: 115
Postby RandyG » Thu Jun 27, 2013 8:50 am
108775
She rivets!
108777
Bow front with 17" radias
108778
Its hard to see but I have a few rear profiles drawn out.
Randy
RandyG
Images: 115
Postby RandyG » Sat Jun 29, 2013 2:37 pm
108865108866108867
I got the side template cut out, just need to go through it with a flush bit for the dados and some sanding.
Randy
RandyG
Images: 115
Postby RandyG » Sun Jun 30, 2013 7:02 pm
108906
Not much done today, I sanded the template and routed some more key points then laid the template over the real walls and sprayed all the edges and dados. Most cutting will be done with a flush bit on the router but the dados will be cut with a guide.
Randy
RandyG
Images: 115
Postby WhitneyK » Sun Jun 30, 2013 9:53 pm
You're movin' along now :thumbsup:
It's going to be an interesting profile / design with the curved front corners and all
Keep up the good work :D
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby RandyG » Mon Jul 01, 2013 10:24 am
Thank you, though it looks like I'm move fast now, I still need some more frame work. After I get the walls cut I need to take it all apart and attach some more bottom panels, ribs, axle, and seal all the wood.
Randy
RandyG
Images: 115
Postby RandyG » Sun Jul 07, 2013 7:17 pm
109201109200109199109198
I got the walls mostly cut out and clamped them in place so I can drill holes through them and the frame so I can attach nutplates inside the frame.
I'm trying to go as far as possible before I have to tear the whole thing down and fine tune each piece.
Randy
RandyG
Images: 115
Postby RandyG » Wed Jul 10, 2013 12:30 am
Currently at a stand still, need to get some poplar 1x2s for the front and spars. Sure to get some after this weekend though... Taking the fam to Six Flags! Very excited.
Randy
RandyG
Images: 115
Postby RandyG » Sat Aug 03, 2013 8:29 am
Picked up a window unit from a friend for $40. I was thinking of setting it into the floor and making a pan for it to sit in, to protect the wood and frame from any dripping.
Randy
RandyG
Images: 115
Postby Junkboy999 » Tue Aug 06, 2013 12:26 am
Randy
Though you like this FB post. It is in the same line as your Avatar.
https://www.facebook.com/notes/alaska-n ... 1446756238
your teardrop is coming along.
Hey I read what you wrote in Ron’s Cross Bow thread but was not sure what part of the models dimensions you want me to change for a model. Was that for the teardrop you were planing? If you have a flat drawing of your profile and some measurement I can model you up one for you.
Junkboy999
Images: 52
Users browsing this forum: Google [Bot] and 13 guests
