starleen2 wrote:Bonnie - Been thinking about your door situation - maybe do then like they do on the pop ups. Have your door folded over on itself so it can hinge open when lowered for access to the inside. Once the top is raised - flip it up and lock it into place. Trying to make an offset door is going to difficult - you might want to check out the hi - lo manufacturer of RV's to see how they did it.
bonnie wrote:So, for those of you who have hacked up fiberglass and such, could I do that? What would I use? Jig saw, my 2x4 saw? Dremel with cutting blade? Should I put the tie down strap back on to keep the top from shifting as I cut?
starleen2 wrote:. . . also when I was building the ladybug - there was a separate discussion on lifting methods for the hatch - might be useful
viewtopic.php?f=2&t=31237&start=15
