Wobbly Wheels wrote:Same problems here as far as handling panels goes, that's one of the main reasons I opted to build the shell and then cut it into smaller pieces to glass it. It makes the panels easier to handle, but it takes more material because I have to tape the seams generously to restore the continuity I would have from glassing it as a singe piece.
I also don't have to glass overhead, which I hate doing. Right now, half of the roof is upside down on the bench where it's warm and the glassing is easy...
Sometimes it seems almost like cheating to use materials that can be sectioned at will, rejoined, and reshaped without making the finished product weaker: once you cut wood, it stays cut.
Handling 3' X 7' panels that weigh maybe 5 or 10 lbs is pretty sweet too....
Looks like you're really getting momentum now, bonnie.
Will it be safe to try to fiberglass the top in that area?
Wobbly Wheels wrote:Will it be safe to try to fiberglass the top in that area?
Yup, epoxy fumes aren't volatile. Using acetone to thin or for cleanup would be more of a threat, but as long as you have enough ventilation that you can't smell it, you won't reach the threshold (lower explosive limit).
That's not to disregard normal safety precautions or the appropriate use of PPE, of course.
Some people , after working with Epoxy develop an allergy to it
