I played a bit with it today, removed the rear sharp radius and ran an arc to the front, didn't like it, but I then left the right corner in the rear, grabbed the center of the straight line and pulled it down 2" into an arc (leaving the two endpoints where they currently are) and it looked a lot better. Just a slight curve but made a huge difference. The drawing is my profile calculation drawing, so it's not fancy, but you get the idea.
Thanks for the feedback!
- ImageUploadedByTapatalk1366341336.489693.jpg (11.95 KiB) Viewed 2209 times
***EDITED***
Took your advise (well some of it) and increased the rear lower radius to 6". I was able to move it up 3" to the bottom of the deck and then ran my lower arc. Still hides the trailer frame, which I was worried about. I think I like it.
- profile3.jpg (15.55 KiB) Viewed 2206 times
