I didn't want more holes in the side (although my finish is not comparable to his, I still have too many holes there already). So, I wanted to attach a table to the metal frame, also removable. I had some legs left from a cheap computer desk I was throwing away, and I re-purposed them by adding plywood I cut to fit my Coleman stove. I added another surface to hold cooking stuff as well. The two pieces of wood are mounted by thumbscrews to the legs, and then the rear legs drop into the eyebolts I mounted on both rear sides of the trailer (use the side you want to avoid wind, sun, or disturbing others). For added stability, just wrap a bungee around the adjacent pipe-clamp stabilizer and/or attach the (not shown) leg spreader/brace to the front legs. Knockdown/assembly time 5 minutes. Weight < 10 lbs.. Stores inside with the mattress folded over it and the cooler stand (also re-purposed material). If needed, the cook stand can be used away from the trailer; the cooler stand is totally free-standing. Here are photos: Details are in my gallery.I am hesitant to muck up my sides
